HI
I just updated to the latest Apple TV Beta of Channels DVR Beta after playing with the options, I some how turned off the option to select settings on the side row how do I make it show up again?
So I can select it again?
Thanks
HI
Thanks
Do you mean kiosk mode?
If so, you can lean how to restore it here:
