Setup Guide Data for Germany
How to Setup the guide for Germany?
Or how to record from the normal guide?
Record is only possible if the guide from the cable Provider is downloaded.
The Channels DVR is installed on an QNAP.
Apple TV found it.
Setup is only possible with Chrome not with Internet Explorer (or with iPad)
Sorry, Channels DVR is not currently available in Germany. We are working on international support.
Yes I know, you write in the Manual.
But it’s only not available because of the guide.
Maybe it’s possible to tell the DVR Software to use the found guide?
If I use the Denmark guide I can record.
But not what I want, the System then use the wrong guide.
The DVR software only works with guide data in one very specific format. It can load up to 21 days of data in this format.
Right now, we do not have German guide data available in this format. So the DVR cannot work in Germany yet.
thanks for the answer.
So I’m sorry I have to cancle my subscription till the new international Software is available,
Any new information on German guide EPG support for Channels? If I understand correctly, without explicit support from Channels, only Silicondust’s 4 hrs of guide information will be available?
