Shield TV Pro 2019 Frequent Connection Lost interruptions
My Shield TV Pro 2019 is nearly unusable for Channels due to connection lost events.
Server (Asustor AS5304T) logs diagnostics submitted ( 5c362bf0-e851-4740-ae1a-a27440e9f1d7).
Shield TV log for a recent event follows.
Situation occurs when watching via TVE and via HDHomeRun. Can easily view same channels (well, the HDHomeRun ones) using Plex and the HDHomeRun app on the Shield.
Shield is connected via WiFi, but shows about 380 Mbps via Channels Support network speed test.
Shield client log:
\SHIELD Android TV
4.6.3-v404240443 (404240443 dvr)
NVIDIA SHIELD Android TV (NVIDIA mdarcy)
HDFX-4K (10A00534) [channels=21, ip=192.168.50.107, auth=kftAICPk-l1YWbS0TrGT4d5J], HDHR5-4K (1080E236) [channels=41, ip=192.168.50.220, auth=OJ_rX_IAG_THXVZOtxOhJ3iB], HDHomeRun CONNECT (10426147) [channels=46, ip=192.168.50.36, auth=KKcqndUo_8SnFBUsVLym-Q0i], HDHomeRun CONNECT (1045BF42) [channels=37, ip=192.168.50.212, auth=CH0LSoUsQyqcbUeZeOwQA15q], YouTube TV (TVE-YouTubeTV) [channels=152, ip=null, auth=null], Pluto TV (M3U-PlutoTV) [channels=361, ip=null, auth=null], Plex Live TV (M3U-PlexLiveTV) [channels=412, ip=null, auth=null], Stirr-for-Channels (M3U-StirrforChannels) [channels=71, ip=null, auth=null], NBC Stream Links (M3U-NBCStreamLinks) [channels=9, ip=null, auth=null]
DVR http://192.168.50.42:8089 Status(os=linux, arch=x86_64, version=2023.05.10.0013, subscription=active, username=byersgl, features=Features(bonjour=true, dvr=true, guide=true))
en_US America/Chicago
SDK 11 (30) arm64-v8a, armeabi-v7a, armeabi
NET wlan0 = [/fe80::f42c:8809:6b21:b81%wlan0, /192.168.50.118]
HDMI available=true channels=2 encodings=[2, 4]
--------- Section deleted to comply with posting characters limit---
-----Remainder of Shield client log follows -----
05-10 14:24:41.613 9478 9524 I libchannels: action=fetchMediaPlaylist url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" status_code=200 status="200 OK" content_length=-1 playlist_count=57 target_duration=2s first_sequence=1 last_sequence=57 time=5.181094ms
05-10 14:24:41.614 9478 9524 I libchannels: action=refetch url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" lock_time=5.93ms first_sequence_number=1 last_sequence_number=57 fetched_first_sequence_number=1 fetched_last_sequence_number=57 number_of_new_segments=0 number_of_removed_segments=0 live=true time=5.975886ms
05-10 14:24:42.282 9478 9527 I libchannels: action=fetchMediaPlaylist url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" status_code=200 status="200 OK" content_length=-1 playlist_count=57 target_duration=2s first_sequence=1 last_sequence=57 time=6.535313ms
05-10 14:24:42.282 9478 9525 I libchannels: action=refetch url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" lock_time=6.772292ms first_sequence_number=1 last_sequence_number=57 fetched_first_sequence_number=1 fetched_last_sequence_number=57 number_of_new_segments=0 number_of_removed_segments=0 live=true time=6.79875ms
05-10 14:24:42.907 9478 9531 I libchannels: action=open url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8/stream57.ts?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" sequence=57 open_status=already_opened status=segmentDownloaded
05-10 14:24:42.949 9478 9527 I libchannels: action=fetchMediaPlaylist url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" status_code=200 status="200 OK" content_length=-1 playlist_count=57 target_duration=2s first_sequence=1 last_sequence=57 time=5.765885ms
05-10 14:24:42.949 9478 9531 I libchannels: action=refetch url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" lock_time=6.014323ms first_sequence_number=1 last_sequence_number=57 fetched_first_sequence_number=1 fetched_last_sequence_number=57 number_of_new_segments=0 number_of_removed_segments=0 live=true time=6.037187ms
05-10 14:24:43.002 9478 9525 I libchannels: action=reader_for_segment sequence=57 offset=0 continuity_counter=0 first_pts=7618233 first_timestamp=84.6470 time=13.489µs
05-10 14:24:43.255 9478 9478 V mpvstats: AV: 79.609 A-V: 0.000 Dropped: 29 Cache: 5.072s video + 5.024s audio
05-10 14:24:43.372 9478 9525 I libchannels: component=monitor segment_average_bitrate=7.6Mbit/sec samples=169 observed_concurrency=0 total=24.5Mbit/sec rate_trend=164.5% rate_trend_10s=164.5% rate_trend_20s=-22.6% average=18.7Mbit/sec max=19.3Mbit/sec requests=4 timeouts=0 unknown_constraint_requests=100%
05-10 14:24:43.616 9478 9524 I libchannels: action=fetchMediaPlaylist url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" status_code=200 status="200 OK" content_length=-1 playlist_count=57 target_duration=2s first_sequence=1 last_sequence=57 time=5.825417ms
05-10 14:24:43.616 9478 9527 I libchannels: action=refetch url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" lock_time=6.089948ms first_sequence_number=1 last_sequence_number=57 fetched_first_sequence_number=1 fetched_last_sequence_number=57 number_of_new_segments=0 number_of_removed_segments=0 live=true time=6.109583ms
05-10 14:24:44.284 9478 9524 I libchannels: action=fetchMediaPlaylist url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" status_code=200 status="200 OK" content_length=-1 playlist_count=57 target_duration=2s first_sequence=1 last_sequence=57 time=6.60849ms
05-10 14:24:44.285 9478 9733 I libchannels: action=refetch url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" lock_time=6.900208ms first_sequence_number=1 last_sequence_number=57 fetched_first_sequence_number=1 fetched_last_sequence_number=57 number_of_new_segments=0 number_of_removed_segments=0 live=true time=6.921354ms
05-10 14:24:44.900 9478 9524 I libchannels: component=controller action=predict_concurrency observed_concurrency=0 previous_target_concurrency=2 content_bitrate=7.6Mbit/sec download_rate=24.5Mbit/sec timeouts_20s=0 timeout_5s_percentage=0% timeout_10s_percentage=0% timeout_20s_percentage=0% timeout_30s_percentage=0% target_bitrate=22.9Mbit/sec decision="external limitation" target_concurrency=2 time=132.917µs
05-10 14:24:44.916 9478 9733 I libchannels: action=status next_variant=0 readers=1 lowest_read_sequence=57 highest_read_sequence=57 first_sequence=1 last_sequence=57 cache_size=78M max_cache_size=5.9G buffer_duration=1.534867s
05-10 14:24:44.920 9478 9531 I libchannels: action=close url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8/stream54.ts?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" sequence=54 close_status=closed status=segmentDownloaded
05-10 14:24:44.920 9478 9524 I libchannels: action=close url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8/stream55.ts?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" sequence=55 close_status=closed status=segmentDownloaded
05-10 14:24:44.920 9478 9531 I libchannels: action=close url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8/stream56.ts?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" sequence=56 close_status=closed status=segmentDownloaded
05-10 14:24:44.951 9478 9525 I libchannels: action=fetchMediaPlaylist url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" status_code=200 status="200 OK" content_length=-1 playlist_count=57 target_duration=2s first_sequence=1 last_sequence=57 time=5.774479ms
05-10 14:24:44.951 9478 9524 I libchannels: action=refetch url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" lock_time=6.063333ms first_sequence_number=1 last_sequence_number=57 fetched_first_sequence_number=1 fetched_last_sequence_number=57 number_of_new_segments=0 number_of_removed_segments=0 live=true time=6.102917ms
05-10 14:24:45.372 9478 9525 I libchannels: component=monitor segment_average_bitrate=7.6Mbit/sec samples=169 observed_concurrency=0 total=24.5Mbit/sec rate_trend=164.5% rate_trend_10s=164.5% rate_trend_20s=47.9% average=18.7Mbit/sec max=19.3Mbit/sec requests=3 timeouts=0 unknown_constraint_requests=100%
05-10 14:24:45.619 9478 9733 I libchannels: action=fetchMediaPlaylist url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" status_code=200 status="200 OK" content_length=-1 playlist_count=57 target_duration=2s first_sequence=1 last_sequence=57 time=6.097657ms
05-10 14:24:45.619 9478 9733 I libchannels: action=refetch url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" lock_time=6.367865ms first_sequence_number=1 last_sequence_number=57 fetched_first_sequence_number=1 fetched_last_sequence_number=57 number_of_new_segments=0 number_of_removed_segments=0 live=true time=6.402657ms
05-10 14:24:46.255 9478 9478 V mpvstats: AV: 82.612 A-V: 0.000 Dropped: 29 Cache: 3.170s video + 3.232s audio
05-10 14:24:46.255 9478 24563 V HTTP : Requesting PUT http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls
05-10 14:24:46.286 9478 9527 I libchannels: action=fetchMediaPlaylist url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" status_code=200 status="200 OK" content_length=-1 playlist_count=57 target_duration=2s first_sequence=1 last_sequence=57 time=4.993073ms
05-10 14:24:46.286 9478 9527 I libchannels: action=refetch url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" lock_time=5.336146ms first_sequence_number=1 last_sequence_number=57 fetched_first_sequence_number=1 fetched_last_sequence_number=57 number_of_new_segments=0 number_of_removed_segments=0 live=true time=5.357552ms
05-10 14:24:46.953 9478 9531 I libchannels: action=fetchMediaPlaylist url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" status_code=200 status="200 OK" content_length=-1 playlist_count=57 target_duration=2s first_sequence=1 last_sequence=57 time=5.123125ms
05-10 14:24:46.954 9478 9525 I libchannels: action=refetch url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" lock_time=5.419062ms first_sequence_number=1 last_sequence_number=57 fetched_first_sequence_number=1 fetched_last_sequence_number=57 number_of_new_segments=0 number_of_removed_segments=0 live=true time=5.456146ms
05-10 14:24:47.372 9478 9531 I libchannels: component=monitor segment_average_bitrate=7.6Mbit/sec samples=169 observed_concurrency=0 total=24.5Mbit/sec rate_trend=164.5% rate_trend_10s=164.5% rate_trend_20s=20.8% average=18.7Mbit/sec max=19.3Mbit/sec requests=2 timeouts=0 unknown_constraint_requests=100%
05-10 14:24:47.623 9478 9733 I libchannels: action=fetchMediaPlaylist url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" status_code=200 status="200 OK" content_length=-1 playlist_count=57 target_duration=2s first_sequence=1 last_sequence=57 time=6.92901ms
05-10 14:24:47.624 9478 9524 I libchannels: action=refetch url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" lock_time=7.303802ms first_sequence_number=1 last_sequence_number=57 fetched_first_sequence_number=1 fetched_last_sequence_number=57 number_of_new_segments=0 number_of_removed_segments=0 live=true time=7.329584ms
05-10 14:24:48.289 9478 9733 I libchannels: action=fetchMediaPlaylist url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" status_code=200 status="200 OK" content_length=-1 playlist_count=57 target_duration=2s first_sequence=1 last_sequence=57 time=5.816146ms
05-10 14:24:48.289 9478 9531 I libchannels: action=refetch url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" lock_time=6.031458ms first_sequence_number=1 last_sequence_number=57 fetched_first_sequence_number=1 fetched_last_sequence_number=57 number_of_new_segments=0 number_of_removed_segments=0 live=true time=6.070677ms
05-10 14:24:48.900 9478 9524 I libchannels: component=controller action=predict_concurrency observed_concurrency=0 previous_target_concurrency=2 content_bitrate=7.6Mbit/sec download_rate=24.5Mbit/sec timeouts_20s=0 timeout_5s_percentage=0% timeout_10s_percentage=0% timeout_20s_percentage=0% timeout_30s_percentage=0% target_bitrate=22.9Mbit/sec decision="external limitation" target_concurrency=2 time=88.49µs
05-10 14:24:49.256 9478 9478 V mpvstats: AV: 85.615 A-V: 0.000 Dropped: 29 Cache: 0.234s video + 0.224s audio
05-10 14:24:49.372 9478 9733 I libchannels: component=monitor segment_average_bitrate=7.6Mbit/sec samples=169 observed_concurrency=0 total=24.5Mbit/sec rate_trend=164.5% rate_trend_10s=164.5% rate_trend_20s=0.0% average=18.7Mbit/sec max=19.3Mbit/sec requests=0 timeouts=0
05-10 14:24:49.770 9478 9520 W mpv : [cplayer] Audio device underrun detected.
05-10 14:24:49.864 9478 9520 W mpv : [ao/audiotrack] getLatency: written=4031377 playhead=4032087 diff=4294966586 delay=89478.470542
05-10 14:24:49.883 9478 24512 D AudioTrack: getTimestamp_l(61): device stall time corrected using current time 12229074920698
05-10 14:24:49.917 9478 9531 I libchannels: action=status next_variant=0 readers=1 lowest_read_sequence=57 highest_read_sequence=57 first_sequence=1 last_sequence=57 cache_size=78M max_cache_size=5.9G buffer_duration=1.534867s
05-10 14:24:51.072 9478 9527 I libchannels: action=fetchMediaPlaylist url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" status_code=500 status="500 Internal Server Error" content_length=-1 time=2.12175802s
05-10 14:24:51.072 9478 9527 I libchannels: action=refetch url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" lock_time=2.122012968s failed=true err="get: http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy: 500 Internal Server Error" live=true time=2.122045259s
05-10 14:24:51.256 9478 24564 V HTTP : Requesting PUT http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls
05-10 14:24:51.372 9478 9524 I libchannels: component=monitor segment_average_bitrate=7.6Mbit/sec samples=169 observed_concurrency=0 total=24.5Mbit/sec rate_trend=164.5% rate_trend_10s=164.5% rate_trend_20s=164.5% average=18.7Mbit/sec max=19.3Mbit/sec requests=57 timeouts=0 unknown_constraint_requests=100%
05-10 14:24:52.257 9478 9478 V mpvstats: AV: 85.698 A-V: 0.000 Dropped: 29 Cache: 0.000s video + 0.000s audio
05-10 14:24:52.900 9478 9733 I libchannels: component=controller action=predict_concurrency observed_concurrency=0 previous_target_concurrency=2 content_bitrate=7.6Mbit/sec download_rate=24.5Mbit/sec timeouts_20s=0 timeout_5s_percentage=0% timeout_10s_percentage=0% timeout_20s_percentage=0% timeout_30s_percentage=0% target_bitrate=22.9Mbit/sec decision="external limitation" target_concurrency=2 time=91.771µs
05-10 14:24:53.372 9478 9733 I libchannels: component=monitor segment_average_bitrate=7.6Mbit/sec samples=169 observed_concurrency=0 total=24.5Mbit/sec rate_trend=164.5% rate_trend_10s=164.5% rate_trend_20s=164.5% average=18.7Mbit/sec max=19.3Mbit/sec requests=57 timeouts=0 unknown_constraint_requests=100%
05-10 14:24:54.919 9478 9531 I libchannels: action=status next_variant=0 readers=1 lowest_read_sequence=57 highest_read_sequence=57 first_sequence=1 last_sequence=57 cache_size=78M max_cache_size=5.9G buffer_duration=1.534867s
05-10 14:24:55.258 9478 9478 V mpvstats: AV: 85.698 A-V: 0.000 Dropped: 29 Cache: 0.000s video + 0.000s audio
05-10 14:24:55.373 9478 9525 I libchannels: component=monitor segment_average_bitrate=7.6Mbit/sec samples=169 observed_concurrency=0 total=24.5Mbit/sec rate_trend=164.5% rate_trend_10s=164.5% rate_trend_20s=164.5% average=18.7Mbit/sec max=19.3Mbit/sec requests=57 timeouts=0 unknown_constraint_requests=100%
05-10 14:24:55.373 9478 9525 I libchannels: action=fetchMediaPlaylist url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" status_code=200 status="200 OK" content_length=-1 playlist_count=1 target_duration=2s first_sequence=1 last_sequence=1 time=4.300132238s
05-10 14:24:55.373 9478 9525 I libchannels: action=refetch url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" lock_time=4.300409999s first_sequence_number=1 last_sequence_number=57 fetched_first_sequence_number=1 fetched_last_sequence_number=1 failed=true temporary_failures=2 err="The Channels DVR Server had a problem. Press play to try again. (Transcoder Reset): Playlist reset to a lower sequence (57 -> 1): http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" live=true time=4.300458072s
05-10 14:24:55.378 9478 9733 I libchannels: action=fetchMediaPlaylist url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" status_code=200 status="200 OK" content_length=-1 playlist_count=1 target_duration=2s first_sequence=1 last_sequence=1 time=4.478646ms
05-10 14:24:55.378 9478 9531 I libchannels: action=refetch url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" lock_time=4.68474ms first_sequence_number=1 last_sequence_number=57 fetched_first_sequence_number=1 fetched_last_sequence_number=1 failed=true temporary_failures=3 err="The Channels DVR Server had a problem. Press play to try again. (Transcoder Reset): Playlist reset to a lower sequence (57 -> 1): http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" live=true time=4.717865ms
05-10 14:24:55.535 9478 24563 V HTTP : Requesting GET http://192.168.50.42:8089/dvr/files/9940?raw=false
05-10 14:24:56.049 9478 9733 I libchannels: action=fetchMediaPlaylist url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" status_code=200 status="200 OK" content_length=-1 playlist_count=2 target_duration=2s first_sequence=1 last_sequence=2 time=7.894792ms
05-10 14:24:56.049 9478 9733 I libchannels: action=refetch url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" lock_time=8.170573ms first_sequence_number=1 last_sequence_number=57 fetched_first_sequence_number=1 fetched_last_sequence_number=2 failed=true temporary_failures=4 err="The Channels DVR Server had a problem. Press play to try again. (Transcoder Reset): Playlist reset to a lower sequence (57 -> 2): http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" live=true time=8.212239ms
05-10 14:24:56.258 9478 24564 V HTTP : Requesting PUT http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls
05-10 14:24:56.743 9478 9733 I libchannels: action=fetchMediaPlaylist url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" status_code=200 status="200 OK" content_length=-1 playlist_count=2 target_duration=2s first_sequence=1 last_sequence=2 time=34.074531ms
05-10 14:24:56.743 9478 9531 I libchannels: action=refetch url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" lock_time=34.390416ms first_sequence_number=1 last_sequence_number=57 fetched_first_sequence_number=1 fetched_last_sequence_number=2 failed=true temporary_failures=5 err="The Channels DVR Server had a problem. Press play to try again. (Transcoder Reset): Playlist reset to a lower sequence (57 -> 2): http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" live=true time=34.432448ms
05-10 14:24:56.900 9478 9733 I libchannels: component=controller action=predict_concurrency observed_concurrency=0 previous_target_concurrency=2 content_bitrate=7.6Mbit/sec download_rate=24.5Mbit/sec timeouts_20s=0 timeout_5s_percentage=0% timeout_10s_percentage=0% timeout_20s_percentage=0% timeout_30s_percentage=0% target_bitrate=22.9Mbit/sec decision="external limitation" target_concurrency=2 time=97.865µs
05-10 14:24:57.372 9478 9531 I libchannels: component=monitor segment_average_bitrate=7.6Mbit/sec samples=169 observed_concurrency=0 total=24.5Mbit/sec rate_trend=164.5% rate_trend_10s=164.5% rate_trend_20s=164.5% average=18.7Mbit/sec max=19.3Mbit/sec requests=57 timeouts=0 unknown_constraint_requests=100%
05-10 14:24:57.382 9478 9527 I libchannels: action=fetchMediaPlaylist url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" status_code=200 status="200 OK" content_length=-1 playlist_count=3 target_duration=2s first_sequence=1 last_sequence=3 time=6.212343ms
05-10 14:24:57.383 9478 9733 I libchannels: action=refetch url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" lock_time=6.448542ms first_sequence_number=1 last_sequence_number=57 fetched_first_sequence_number=1 fetched_last_sequence_number=3 failed=true temporary_failures=6 err="The Channels DVR Server had a problem. Press play to try again. (Transcoder Reset): Playlist reset to a lower sequence (57 -> 3): http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" live=false time=6.49526ms
05-10 14:24:57.383 9478 9733 I libchannels: action=wait_for_more_segments time=12.892534422s
05-10 14:24:57.383 9478 9733 I libchannels: action=read sequence=57 offset=0 buf.cap=49536 n=0 done_reading=true werr="The Channels DVR Server had a problem. Press play to try again. (Transcoder Reset): Playlist reset to a lower sequence (57 -> 3): http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" time=12.892817443s
05-10 14:24:57.383 9478 9733 I libchannels: action=read sequence=57 offset=0 buf.cap=49536 n=0 done_reading=true nerr="The Channels DVR Server had a problem. Press play to try again. (Transcoder Reset): Playlist reset to a lower sequence (57 -> 3): http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" time=27.448µs
05-10 14:24:57.383 9478 9733 I libchannels: action=read sequence=57 offset=0 buf.cap=49536 n=0 done_reading=true nerr="The Channels DVR Server had a problem. Press play to try again. (Transcoder Reset): Playlist reset to a lower sequence (57 -> 3): http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" time=21.979µs
05-10 14:24:57.384 9478 9531 I libchannels: action=read sequence=57 offset=0 buf.cap=49536 n=0 done_reading=true nerr="The Channels DVR Server had a problem. Press play to try again. (Transcoder Reset): Playlist reset to a lower sequence (57 -> 3): http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" time=24.948µs
05-10 14:24:57.384 9478 9520 V mpv : [lavf] EOF reached.
05-10 14:24:57.385 9478 9520 V mpv : [af] filter input EOF
05-10 14:24:57.386 9478 9520 V mpv : [af] filter output EOF
05-10 14:24:57.386 9478 9520 V mpv : [cplayer] audio filter EOF
05-10 14:24:57.386 9478 9520 V mpv : [cplayer] restarting audio after underrun
05-10 14:24:57.386 9478 9520 V mpv : [cplayer] audio draining
05-10 14:24:57.403 9478 24512 W AudioTrack: restartIfDisabled(61): releaseBuffer() track 0x24073c7a40 disabled due to previous underrun, restarting
05-10 14:24:57.410 9478 9520 V mpv : [cplayer] AO signaled EOF (while in state draining)
05-10 14:24:57.741 9478 9520 V mpv : [vf] filter input EOF
05-10 14:24:57.741 9478 9520 V mpv : [vf] filter output EOF
05-10 14:24:57.741 9478 9520 V mpv : [cplayer] video EOF reached
05-10 14:24:57.741 9478 9520 V mpv : [cplayer] EOF code: 1
05-10 14:24:57.741 9478 9520 D mpv : [ad] Uninit decoder.
05-10 14:24:57.742 9478 9520 V mpv : event: audio-reconfig
05-10 14:24:57.742 9478 9520 D mpv : [vd] Uninit decoder.
05-10 14:24:57.743 9478 9520 V mpv : event: video-reconfig
05-10 14:24:57.754 9478 24503 D SurfaceUtils: connecting to surface 0x2487327100, reason connectToSurface
05-10 14:24:57.754 9478 24503 I MediaCodec: [OMX.Nvidia.mpeg2v.decode] setting surface generation to 9705478
05-10 14:24:57.754 9478 24503 D SurfaceUtils: disconnecting from surface 0x2487327100, reason connectToSurface(reconnect)
05-10 14:24:57.754 9478 24503 D SurfaceUtils: connecting to surface 0x2487327100, reason connectToSurface(reconnect)
05-10 14:24:57.754 9478 24504 D SurfaceUtils: set up nativeWindow 0x2487327100 for 1920x1080, color 0x106, rotation 0, usage 0x2900
05-10 14:24:57.755 9478 24503 D SurfaceUtils: disconnecting from surface 0x248730d840, reason disconnectFromSurface
05-10 14:24:57.755 9478 24503 E Surface : freeAllBuffers: 4 buffers were freed while being dequeued!
05-10 14:24:57.766 9478 9531 I libchannels: action=close url="http://192.168.50.42:8089/devices/1080E236/channels/9.1/hls/stream.m3u8/stream57.ts?acodec=copy&bitrate=4516&format=copy&indexed=true&scodec=copy&ssize=1&vcodec=copy" sequence=57 close_status=closed status=segmentStopped
05-10 14:24:57.766 9478 9520 V mpv : event: audio-reconfig
05-10 14:24:57.769 9478 24503 D SurfaceUtils: disconnecting from surface 0x2487327100, reason disconnectFromSurface
05-10 14:24:57.806 9478 9524 I libchannels: action=close time=40.284323ms
05-10 14:24:57.806 9478 9520 V mpv : event: tracks-changed
05-10 14:24:57.806 9478 9520 V mpv : event: end-file
05-10 14:24:57.806 9478 9520 V mpv : [cplayer] finished playback, success (reason 0)
05-10 14:24:57.806 9478 9478 V PlayerActivity: state PLAYING -> STOPPED
05-10 14:24:57.806 9478 9520 I mpv : [cplayer]
05-10 14:24:57.812 9478 9520 D mpv : [vo/mediacodec_embed] flushing shader cache
05-10 14:24:57.815 9478 9520 V mpv : event: video-reconfig
05-10 14:24:57.816 9478 9478 V mpv : command: script-message-to stats clear-stats
05-10 14:24:57.817 9478 9520 V mpv : event: idle
05-10 14:24:57.817 9478 9520 V mpv : property: buffering = false
05-10 14:24:57.818 9478 9520 V mpv : property: track-list has 0 entries
05-10 14:24:57.818 9478 9520 V mpv : [cplayer] Set property: aid=1 -> 1
05-10 14:24:57.831 9478 9478 E libc : Access denied finding property "ro.vendor.sys.NV_ASYNC"
05-10 14:24:57.831 9478 9478 E libc : Access denied finding property "ro.vendor.sys.NV_LOGFPS"
05-10 14:24:57.832 9478 9478 E libc : Access denied finding property "ro.vendor.sys.NV_PROCESS_NAME"
05-10 14:24:57.832 9478 9478 E libc : Access denied finding property "ro.vendor.sys.NV_FPSDYNAMIC"
05-10 14:24:57.840 9478 9478 V PlayerActivity: Video Error Message: Connection Lost: The Channels DVR Server had a problem. Press play to try again. (Transcoder Reset)
05-10 14:24:58.356 9478 9478 V mpvstats: AV: 0.000 A-V: 0.000 Dropped: 0 Cache: 0.000s video + 0.000s audio
05-10 14:24:58.725 9478 24563 V HTTP : Requesting GET http://192.168.50.42:8089/dvr/files/9940?raw=false
05-10 14:25:04.484 9478 24564 V HTTP : Requesting GET http://192.168.50.42:8089/dvr/files/9940?raw=false
05-10 14:25:10.453 9478 24563 V HTTP : Requesting GET http://192.168.50.42:8089/dvr/files/9940?raw=false
05-10 14:25:10.469 9478 24564 V HTTP : Requesting GET http://192.168.50.42:8089/dvr/groups/17952014
05-10 14:25:16.556 9478 24563 V HTTP : Requesting GET http://192.168.50.42:8089/dvr/files/9940?raw=false
05-10 14:25:22.513 9478 24564 V HTTP : Requesting GET http://192.168.50.42:8089/dvr/files/9940?raw=false
05-10 14:25:52.193 9478 24563 V HTTP : Requesting GET http://192.168.50.42:8089/dvr/files/9940?raw=false
05-10 14:25:54.209 9478 24564 V HTTP : Requesting GET http://192.168.50.42:8089/dvr/files/9940?raw=false
05-10 14:25:58.511 9478 24563 V HTTP : Requesting GET http://192.168.50.42:8089/dvr/files/9940?raw=false
05-10 14:26:04.545 9478 24564 V HTTP : Requesting GET http://192.168.50.42:8089/dvr/files/9940?raw=false
05-10 14:26:10.545 9478 24563 V HTTP : Requesting GET http://192.168.50.42:8089/dvr/files/9940?raw=false
05-10 14:26:16.538 9478 24564 V HTTP : Requesting GET http://192.168.50.42:8089/dvr/files/9940?raw=false
05-10 14:26:22.935 9478 24563 V HTTP : Requesting GET http://192.168.50.42:8089/dvr/files/9940?raw=false
05-10 14:26:25.996 9478 24727 V ApiServer: REQUEST: GET /log
