I've noticed that that the top shelf doesn't show the channel logos and only shows a picture of the show that's on (if recognised and available) or just the tv box with the channel name. Is this normal behaviour? Can this be enabled for NZ?
This will be fixed in the next version.
This is fixed in v2.1.34, now available on the App Store
hi just updated to the latest version. Upgraded the firmware but still not getting all the channel logos for NZ? I have tried refreshing the device and scanning for channels.
cheers
Warwick
What firmware are you on?
I’m using 20170612beta1 and it’s working fine.
Which channel logos aren’t you getting?
Also have you tried restarting your ATV?
Yip, I’m using 20170612beta1 and I have restarted my ATV.
I don’t get tv one, bravo, tv one +1, tv+2, bravo +1, Shine.
im not on the beta version of channels so not sure if that has any effect?
Are you using “EPG from SiliconDust”?
