Small thing but useful. When you switch the TV on and look at the guide, you have no idea if the program you’re looking at has just started or not. A vertical line representing the current time, going across all current programs displayed on the guide would be great. Thanks!
I second this, small detail but would be nice to have
If you use an Apple TV, there is a small indicator at the top of the guide that represents the current time.
Even just adding a small digital clock in the top right corner of the guide would be very useful.
Also, adding an indicator ( maybe a left-pointing arrow/triangle) indicating that the current show started in a previous time block.
A clock would take too much real estate and there is already a “clock” in the guide that would work fine if the tick-mark in the orig suggestion is implemented.
Need clock not just on guide, but on list of current recordings, and on "Live TV".
Ken
If I could request one feature to add right now, it would be adding a clock. Mostly on the guide, but other areas would be nice too.
