Shutdown safe switch
Is there an easy way to shutdown safely via a local, physical button?
Occasionally, I need to shutdown/reboot my raspberry and for reasons beyond my skill set, the online access to the server is unavailable. I end up yanking power and then have to repair the corrupt sd card.
Raspberry Pi Safe Reboot and Shutdown Button - learn.sparkfun.com.
You might want to check out our custom Raspberry Pi image that was designed specifically to boot off a hard drive rather than an SD card, just because SD cards can be unreliable like this.
While it’s never a great idea to just unplug any computer, installing Channels this way can be a little more reliable.
I’ve got it booting from a usb flash drive already. Is this method any better that that?
Doesn’t this require coding integrated into the channels operating system?
