Sideways virtual channel
So I’ve been playing around with a virtual channel for home videos shot with iPhone. Everything went good except my shield tv pro displays all videos shot in portrait orientation sideways when watching in virtual channel or from library. What I mean is the bottom of video (like grass) is on the right of screen and the top(like the sky) is on the left of screen. The shield tv does display videos shot in landscape properly. This does not happen in iPhone and iPad app, and is correct and working properly with those clients.
Track #0: H.265 / HEVC (High Efficiency Video Coding)
3840x2160 yuv420p 59.94fps
Track #1: AAC (Advanced Audio Coding)
stereo und 186.725kbps
Channels v4.0.1
NVIDIA SHIELD
AndroidTV 9 API/28
Dvr Version 2021.11.01.0011
Is this a known bug? Search came up with nothing. Thanks
Any difference with Settings > Playback > Advanced > Video Driver set to Hybrid or Software?
I’ll check those when I get home and report back
This is a fascinating way to use virtual channels and honestly one of the better reasons to support Home Videos with Local Content.
Ya it actually works wonderfully(minus the sideways thing). The wife melted when some older toddler videos of the kids came up. I think it’s the first time she watched tv for more than a single recorded tv episode. Couple of small annoyances I’ve found so far but I doubt will be able to be fixed. 1. Obviously most vids are only a couple minutes long, so when trying to click on the current stream of virtual channel is difficult. 2. I don’t really want 200plus short videos showing in the library. Solved by hiding from library but that’s a lot of work to go in individually and hide. A manual setting to hide all movies from the library that do not have a cover art or something possible? Pretty small use case I’m sure so I won’t hold my breath. lol
Yeah, not much you can do about that. If I were you, I’d use some merging tools and just start merging the videos together to be longer videos.
Curious, does clicking on the virtual channel logo in the guide present an on later view like a normal channel does?
It does but it warns that there’s no content.
What Maddox said
Hardware plays video well but it is sideways
Hybrid and software play like slow motion with tons of dropped frames. Unwatchable on hybrid and software. However the video orientation is correct on hybrid and software
In my brief search I didn’t come up with any merging software that does both hevc and runs on Linux. Any ideas?
Maybe with LosslessCut.
In this video, the guy is doing it on Windows but LosslessCut is also available for Linux so it should work the same.
Generally speaking, ffmpeg is the main engine that handles video processing. You could also do it on the command line.
MKVToolNix works, but I usually just go with Ffmpeg.
Still sideways on shield tv with decode set to hardware within client. Software and hybrid show correct orientation but both software and hybrid are unwatchable with pauses @ 4k60fpsHevc content and hybrid has terrible picture quality with 4k30fpsHevc. Server set to hardware transcoder. Setting hardware or linear deinterlacer makes no difference. iOS client correct with default video driver, sideways with experimental video driver. @eric. I’m not really sure why the shield player is downscaling to 1080p60fps in the stats screenshot
That setting is only for web or remote clients. It has no influence upon actual client apps.
I can guarantee you the deinterlacer settings have a bunch to do with local clients when dealing with hevc content. That’s why changing it to linear in the past allowed that content to be played local or remote
@Rice Is it fixed if you change the Streaming Quality to 8mbps?
I'm not sure how much control we have over this with the hardware decoder on the Shield, but we can look into it.
Yes I forgot to mention that earlier. Yes when playing at a transcoded 8MB,ect stream they display correctly on the shield(with hardware decode). They also now play correctly in the web player 10mb. So progress has been made on this but I’m not really willing to go non-original quality at home. iPhone videos played back on a android shield, I’m not really surprised they don’t play well together.
So the issue only remains with original quality (i.e. no transcoding on server) + shield hardware decoding?
Does VLC on the same shield (with hardware accel enabled) play it correctly?
Same file on a usb plugged into the shield using VLC, VLC settings>hardware acceleration plays correctly on Full acceleration and automatic. Skips and pauses on decoding acceleration but all three choices do play in the correct portrait orientation.
