There are a lot of “SIGN OFF” slots in my guide data for my major network channels ABC, CBS and NBC. I’ve set these channels up as custom stream links so I’m not sure if that has anything to do with it…
Is this normal?
Is this normal?
That means you picked a station id or guide mapping which doesn't have local programming. You need to pick the one that goes with the callsign of the station you get in the corresponding app.
I guess I’m not quite sure how to do this?
That did the trick! Does the station ID matter in the text of the stream link? I got them by going to zap2it and viewing the source of the logo image as someone suggested on the forum.
The ones you got from zap2it are wrong and that's the problem. If you entered your zipcode into zap2it first then maybe they would have been more correct.
But since you mapped it via the UI that takes precedence and you can remove the stationid from the text.
