I have the HDHomeRun FLEX 4K Development version which reports signal strength in dBm and signal quality as a SNR in dB. Currently when I bring up the "show stats" page on Channels for HDHomeRun, it shows "0" under the signal strength and signal quality.
Signal GH has been able to simultaneously display both dBm, SNR, and percentage info for a given channel for those of us with the development version. Would you be able to add this?
Thanks.
