Signal Strength - HDHOMERUN
I have gone through a bunch of posts on here....and I thought I found my answer.....my question is how can I see the signal strength of the OTA channels that I am running through Channels via HDHOMERUN....the responses I see say to togo myhdhomerun.com and it will give me the IP address of my device...then use UI....When I goto myhdhomerun.com, it does not give me the option to see the status or IP of my device...any help is much appreciated. I want to try to adjust the direction of my OTA antenna tonight, but can't see what the signal strengths are.
Again, any help is much appreciated. Thanks.
You’re probably using safari or a Mac. It doesn’t work there, for some reason.
Find your HDHomeRun’s IP address and just go to it directly. Use your router, or check the ip in the Sources section of your Channels DVR Server.
You can also get this info while watching live tv in Channels by showing stats. Do this in the Options section of the Quick Menu while watching something.
Well that gave me the IP address and the signal strength..BAM!!!! Thank you so much!
