Can I use a single HDHR 4 tuner and have channels and plex access it at the same time. I have it setup that way now and it seems to work. I have not tried to access the HDHR from plex and channels at the same time though. Thanks.
Plex does not share tuners … it assumes all tuners are allocated to it. So if channels is using a tuner PLEX might try to use it and fail.
Ok - thanks. I've removed the tuner from plex.
