I suddenly lost the bill of stations accessible through TVE, like MSNBC, FX, CNN, etc. did something change with Sling?
Are the TVE's working directly on MSNBC ect...
TVE support is the worse with Sling.
have you removed the account and added it back? I have had this issue with philo.
Yes, I did that twice, and it didn’t make a difference
You don't mention these, so not sure if you tried them.
Applies to all TVE Providers, not just Sling.
Try to login to the networks live streaming websites using your Sling credentials for the ones you have issues with Channels Support - TV Everywhere Availability for SlingTV
If you can't login to those websites, nothing Channels can do to get them.
If you can login to those websites, then continue.
Update the DVR server to the latest pre-release version.
Update the chrome browser on your server unless Channels supplies it for your OS's install.
Try to add the source again (sometimes clicking and HOLDING the Login button helps).
If it won't work, submit diagnostics from the dvr web UI.
If it adds the source, continue.
Try rescanning any individual channels having issues.
If you still have issues, submit diagnostics from the dvr web UI.
