WIth the announcement that Slingbox is ending. I need to explore other options. What is the difference between the 2.
Many thanks in advance
This is a really broad question. There's a huge difference.
Channels is a full DVR system that allows you to watch and record live tv with the ability to stream it from your house while away from home.
Slingbox was a device that basically took input and created it's own video stream to let you stream anything that was inputted to it, while away from home. It was basically just a video encoder with an IR emitter that controlled devices.
Check out our site to see what the Channels product offering is:
