Channels Version: 2023.08.07.2138
MCEBuddy 2.5.7
Comskip 0.82.003 (donator)
This may or may not be a Channels issue. Though I am starting to suspect the original recorded files may be the issue. I use MCEBuddy to cut commercials and transcode, but I imagine this community is familiar enough with the software to figure out where the problem may be.
I noticed that some episodes recorded from FXX (also FX) show a frame rate of 29.97 while others show 59.94. Episodes that are 29.97 have no issue and take 2-4 minutes in the ad scan, But ones that show a frame rate of 59.94 will take over 1hr 15min for the ad scan.
I've tried different settings in MCEBuddy, as well as different comskip.ini files. I'm currently running tests on different networks. An episode on FX and Disney are also having the same frame rate/long ad scan time issues.
Here's what a good comskip log looks like:
Input #0, mpegts, from 'T:\apps\MCEBuddy\temp\working0\King of the Hill S05E01 2000-10-01 The Perils of Polling 2023-08-08-1300-wk.ts': Duration: 00:30:27.01, start: 1.400000, bitrate: 6181 kb/s Program 1 Metadata: service_name : Service01 service_provider: FFmpeg Stream #0:0[0x100]: Audio: aac (HE-AAC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 136 kb/s Stream #0:1[0x101]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, progressive), 1280x720 [SAR 1:1 DAR 16:9], 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc Frame Rate set to 29.970 f/s Format changed to [1280 : 720] Frame: 1 Channels: 0 Initial audio pts = 0.000 Initial video pts = 0.017 Frame Rate set to 59.940 f/s DFps[1]= 29.970 f/s RFps[1]= 29.970 f/s AFps[1]= 29.970 f/s Frame: 2 Channels: 2 Frame 2 (0.000s) - Black frame because large scene change of 99, uniform 43516 Initial video pts = 0.033 Framerate forced to 29.97fps at frame 7 Frame Rate set to 29.970 f/s Frame: 2 Ratio: 1.78 MinY: 1 MaxY: 720 MinX: 1 MaxX: 1280 Frame 104 (3.370s) - Uniform frame with brightness of 16 and uniform of 0 Frame 105 (3.403s) - Uniform frame with brightness of 16 and uniform of 0
And here's what the bad ones look like:
Input #0, mpegts, from 'T:\apps\MCEBuddy\temp\working0\King of the Hill S05E02 2000-11-05 The Buck Stops Here 2023-08-08-1330-wk.ts': Duration: 00:30:39.15, start: 1.400000, bitrate: 6216 kb/s Program 1 Metadata: service_name : Service01 service_provider: FFmpeg Stream #0:0[0x100]: Audio: aac (HE-AAC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 124 kb/s Stream #0:1[0x101]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, progressive), 1280x720 [SAR 1:1 DAR 16:9], Closed Captions, 59.94 fps, 59.94 tbr, 90k tbn, 119.88 tbc Frame Rate set to 59.940 f/s Format changed to [1280 : 720] Frame: 1 Channels: 0 Initial video pts = 0.008 Frame Rate set to 119.880 f/s DFps[1]= 59.940 f/s RFps[1]= 59.940 f/s AFps[1]= 59.940 f/s Frame Rate corrected to 59.940 f/s Frame 2 (0.000s) - Black frame because large scene change of 96, uniform 35308 Initial video pts = 0.017 Frame Rate set to 119.880 f/s DFps[1]= 59.940 f/s RFps[1]= 59.940 f/s AFps[1]= 59.940 f/s Frame Rate corrected to 59.940 f/s Frame Rate set to 119.880 f/s DFps[1]= 59.940 f/s RFps[1]= 59.940 f/s AFps[1]= 59.940 f/s Frame Rate corrected to 59.940 f/s Frame Rate set to 119.880 f/s
Which continues on for some time.
EDIT: it's the older version of comskip that's bundled with MCEBuddy. When I point MCE to the comskip bundled with Channels it works as expected.
