Smart Rule
I'm trying to extend my use of Channels for a new user and want to build a Collection using Smart Rule. However, I'm running into an issue. Using Summary=[words in summary] seems to work. Title is documented in the Help, but it doesn't appear in the drop down list. It doesn't seem to work when hand typed. either.
I think it uses Name= for shows
Yes, name is what's needed for filtering by names of TV shows.
@tmm1 Would you please consider adding "Name" to the simple mode Smart Rule options for Library Collections and Playlists?
It would be nice to not have to be stuck in advanced mode just to use the "Name" field.
Yes, Name= works. Thanks.
Any hints on "Advanced Mode" syntax? Boolean logic? The help gives no examples, only lists keywords (omitting "name"). Doesn't mention the set syntax (brackets). Or the comparison operators.
