I've got multiple versions of some movies - 1080p and 4K (coming from my Plex server). In Channels I only want to see the 4K versions (when I have both versions imported). Is there a way using Advanced Editor to get a query like that?
Unfortunately I don’t think there is anyway to quickly do this with automation right now.
Only way I can think is to create a ‘Duplicate’ label for all your none 4K duplicate versions and then you can use the smart rules to not include those with that label.
But depending on your library size that may not be 2 seconds work.
Hmmmm…I hadn’t thought of going that route. I don’t have a ton of 4k content so it really wouldn’t take that long.
You can also simply just go to visibility and then untick it from Library.
Whichever way you think will suit you more.
