The Sony Android TV has a powerful CPU, why does the Android version seem crippled compared to the FireTV 4k stick? The FireTV 4k works very well mostly. It does however play at what appears to be 8 frames per second that is fixed with a skip Fwd or back.
-With surround sound on, 480i channels fail to play unless I skip back once. HD channels seen to play fine but will buffer randomly after some time so the only way for it to wish right is with surround off. The lip sync never gets in sync, is always slightly off.
-One last thing, can you enable DD5.1 Passthrough so it's surround only when the broadcast is 5.1.
Thanks! That's it for now.
