Some recorded shows from TVE won’t play but others will
I’ve got something odd happening where it seems like some season pass recordings play back fine but others just sit at 0 min with the loading circle icon next to the time going indefinitely. I’m running on a stock PI DVR server. It seems to only be happening to season passes on MSNBC for me. I submitted log files for the video player in case that’s helpful.
What app/device for playback? There were issues with MSNBC playback fixed in the latest versions of the apps.
Playback is on a TiVo stream, sorry I should’ve mentioned that. Should I try and force an app update?
What version is shown in the Channels app under Settings > Support > About
It should be v4.0.1 ideally. You can go into the Play Store and search/update
Mine says 3.5.2, so it sounds like I’m out of date.
That solved it! Thanks, and thanks for the quick response!
