Travel Channel, Animal Planet, HGTV, TLC, Investigation Discovery, Motortrend HD aren’t showing up in my channels server. I tried rescanning and still not showing up. You think I show get the prerelease version of the server? All the of these channels I can sign in on there app or website and are able to watch it from there.
I would update to the latest prerelease server version and rescan.
If rescan still doesn't work, remove and re-add the Spectrum-TVE source.
With spectrum you don’t want to do a full rescan if you can avoid it, as they will lock you out temporarily for too many attempts. Open the lineup and edit it, then find the channel in the list and scan it individually.
Good point. Wasn't aware of that.
Xfinity used to force a password reset on me, but not recently.
I've had to remove and re add Xfinity-TVE twice in the last month.
Copy that! Thanks! Does it take up to and hour or two to be able to re authorize?
If you’re getting the too many logins error, then yes you will have to wait. If you’re getting that I’d wait until the following day to try again.
