The Devs would have to confirm but I believe the client-side buffer may be handled differently when viewing live versus DVR recorded content. I seem to remember one of them mentioned there is less client-side buffering when watching a DVR recording because it can always go back to the server for more if needed. However, when viewing live content, the client is responsible for all the buffering, and much more of a buffer may be retained on the local client. If my memory is correct and the issue is related to this, the problem might be with the storage on these devices. Perhaps it is slow or flaky, causing issues for the local buffer. Just speculating.
I would agree if, all video players used on this device with the same content had the same problem. That makes me scratch my head.
I have posted a log and a video in the Fox news thread since using the new beta app that enabled Software and hybrid decoding have been enabled fixed almost every problem I was having except for streaming live on TVE. The log appears to show some sort of buffering issue.
The video shows the buffering experience with the growing timeline and then it also shows me going back after and replaying the buffering event to show it is playing smooth without any missing data.
Definitely some good insight that it is likely a buffering problem. I did have surround sound enabled with causes some issues with OTA SD channels mainly that is well known. I switched back to stereo and am testing again.
> 03-31 23:43:00.262 17789 17837 V mpv : [lavf] EOF reached.
> 03-31 23:43:00.278 17789 17837 V mpv : event: unpause
> 03-31 23:43:00.279 17789 17837 V mpv : event: unpause
> 03-31 23:43:00.279 17789 17837 V mpv : [cplayer] End buffering (waited 49.981429 secs) [0.000000s].
> 03-31 23:43:00.279 17789 17837 V mpv : [af] filter input EOF
> 03-31 23:43:00.279 17789 17837 V mpv : [af] filter output EOF
> 03-31 23:43:00.279 17789 17837 V mpv : [cplayer] Enter buffering (buffer went from 100% -> 0%) [0.000000s].
> 03-31 23:43:00.280 17789 17837 V mpv : [cplayer] Still buffering (buffer went from 0% -> 4%) [0.042667s].
> 03-31 23:43:00.281 17789 17837 V mpv : [cplayer] Still buffering (buffer went from 4% -> 0%) [0.000000s].
> 03-31 23:43:00.284 17789 17837 V mpv : [cplayer] Still buffering (buffer went from 0% -> 4%) [0.042667s].
> 03-31 23:43:00.284 17789 17837 V mpv : [cplayer] Still buffering (buffer went from 4% -> 21%) [0.213333s].
> 03-31 23:43:00.318 17789 17837 V mpv : event: unpause
> 03-31 23:43:00.318 17789 17837 V mpv : [cplayer] End buffering (waited 0.044195 secs) [1.066667s].
> 03-31 23:43:00.322 17789 17837 V mpv : property: buffering = false
> 03-31 23:43:00.322 17789 17789 V PlayerActivity: state BUFFERING -> PLAYING
> 03-31 23:43:00.432 17789 17837 E mpv : [ffmpeg/video] h264: error while decoding MB 52 37, bytestream -16
> 03-31 23:43:00.432 17789 17837 V mpv : [ffmpeg/video] h264: concealing 637 DC, 637 AC, 637 MV errors in P frame
> 03-31 23:43:00.457 17789 17789 V mpvstats: AV: 1728.879 A-V: 0.000 Dropped: 10 Cache: 1.536s + 0KB
> 03-31 23:43:00.757 17789 17789 V mpvstats: AV: 1729.146 A-V: 0.000 Dropped: 10 Cache: 1.280s + 0KB
> 03-31 23:43:01.996 17789 17837 V mpv : event: unpause
> 03-31 23:43:01.996 17789 17837 V mpv : [cplayer] Enter buffering (buffer went from 100% -> 0%) [0.000000s].
Buffer is stored on the client device.
How much storage space is on the device?
If it gets full, then there will be issue.
or if the internal storage is too slow or busy to handle the i/o, also cause issues.
but the logs would indicate that.
Plenty, 3.7GB available. This ONLY happens with TVE content.
I think that is quite low actually.
HD files can be quite large once the buffer fills up. i think 90 min is the limit.
but again, u woudl see errors in the log of low or out of space. so not that most likely
TVE content is lower bit rate so does use less space.
Have u run a disk i/o benchmark just to see if the read/write speeds are good?
Is there a way to add in additional storage like a fast micro sd card or usb 3.0 stick?
I have my Shields setup so that the external storage i added on to it is formatted as internal shared storage. dont know if a ATV set has that kinda option.
But yea, if only TVE streams with issue and not OTA or local files.....I don't for see storage being a factor......
that is a weird one.
The buffer only needs to be large enough for the current being played.... Any buffering/recording from pausing is all done on the DVR.
No, not true. The playback buffer for live TV is local to the client. The DVR only maintains a minimal buffer for TVE/Locast streams. Also, while a small cache is used for transcoded programs, it is not used for timeshifting in any way.
The more free space there is on the client device, the longer/larger its live buffer is.
I know the buffer is.... I'm saying any buffer you have from pausing is saved on the DVR.
If that's not accurate then I'd love to know.
the whole buffer is stored on the device. so if u pause it for say 60 min, u wil have used say like 2GB or whatever.
it has been stated here before in places...i see if i can find the posts via search.
Not accurate. The pause buffer is local to the client only.
Thank you for the informative response. I hate crow
Either way I've never paused for more than 10 minutes.
If this is so, and u do have HW decode enabled in settings, then the MPV player did use Software decode.
Perhaps, the URL streams u are using it for only work with SW.
Does it play with HW if you play a local file from your storage drive?
like a h264 .mp4 or .mkv?
On my Shield, HW decode is working, it has HW on the OSD bar and it reports in the INfo stats OSD, "hwdec: mediacodec-copy" if it is SW, it lists nothing.
Anyway to tell if VLC is using HW or SW when it plays the same URL stream?
I use VLC just to load my CCTV cams, using RTSP.
I have a Sony TV with android and have this problem. I usually watch recordings not live shows and it usually only happens on Broadcast networks using HDHR(connected to switch then router). Its usually the 1st few seconds of the prorgram or about half way through after a commercial skip. The screen pixelates or freezes and the the audio usually continues, then the picture speeds up to to catch up to audio. Sometimes the audio cuts out. I have not tried to view that portion of the broadcast directly from the server interface but will try that next time it happens.
I assumed it was something to do with my setup for the DVR or might need an LTE filter. I am currently using a laptop with USB3 external hard drive. My set up is Modem connected to Router, laptop is wireless, switch connected to router, HomeRun and Android TV connected to switch. I know I should connect laptop to switch but I'm to get PC tower to move server to.
You can fix this by installing the New beta app and setting the Decoder to Hybrid or Software. At least that is fixed. The ONLY issue I see now is while watching Live TVE channels.
Glad you’re planning to hardwire your server. You will likely see improved performance when you do so.
I have been using Channel DVR for almost 2 years now. I still have the problem with Fire TV and Sony Android TV. Works great on Apple TV. Have contacted support a couple of times no fix. Wondering if I should do my yearly renewal this coming February
See:
