Why is there no sort order for Channels DVR recordings on Android TV? I am on the beta. Nvidia Shield. On the Apple TV version, you may reverse the sort order from old to new (season/episodes), and vice versa.
Thanks in advance.
Thanks in advance.
Did you check Settings > Library > Airing Order? Changing that will adjust the sort order used when viewing a single program: "Oldest first" puts the episode list in chronological order, with the oldest episode selected, and newer episodes to the right; "Newest first", puts your list in reverse chronological order, with the newest episode initially selected.
I thought I checked everything! I will look tonight. Thank you very much.
