Sort Recordings
Is there an option to sort recordings?
On the ATV's in the house, they all show the most recent recordings. Ideally, multiple episodes of the same show would be grouped together.
Thanks,
Jeff
You can access your recordings grouped by TV show via the TV shows section.
This section is accessible via a button in the Library section, or you can use settings to add the TV Shows section directly to your side bar navigation.
