OK...here is the info from the NBC stream:
TV/The Dr. Oz Show/The Dr. Oz Show S11E160 The Coronavirus Pandemic What Could the New Normal Look Like 2020-05-05-1459.mpg
Duration
58 sec
Bit Rate
8,319,144 bits/sec
File Size
60,588,640 bytes
File ID
656
Streaming Index
Up to date
Channel
12.1 NBC
Track #0: MPEG-2 video
1920x1080 16:9 yuv420p interlaced 29.97fps
Track #1: ATSC A/52A (AC-3)
stereo eng 384kbps
Track #2: ATSC A/52A (AC-3)
stereo spa 192kbps
Here is the detail from the CBS stream:
TV/Let's Make a Deal/Let's Make a Deal S11E148 2020-05-05-1450.mpg
Duration
10 min
Bit Rate
8,602,406 bits/sec
File Size
614,041,652 bytes
File ID
655
Streaming Index
Up to date
Channel
5.1 CBS
5.1(side) eng 384kbps
stereo spa 192kbps
I see where track #1 is different, and I'm assuming that's what is causing the issue. What I don't understand is, if I connect my antenna to my tv directly, both of these stations will play in 5.1. I am only getting the stereo issue while watching through the DVR (both live and recorded).
Any idea what to do? Any idea why?
