I have been trying out the Onn Android TV Streamer off and on for a while to see if it would be a better device than my TS4K. However, I have an issue that makes it pretty much unusable.
Channels DVR (and Hulu and Amazon Prime) all have incredibly low volume levels. So low that if I turn it up to a reasonable volume, switching to any other app, the home screen, or another input results in way way too loud volume.
Just for reference, this happens on my Samsung QN65Q7DRAFXZA TV with or without my Sonos Beam plugged into the ARC port. As I am typing this, I realized that I haven't tested the device on my other TV (I might try that tomorrow if I remember).
This seems to be an issue with the Onn device, as nothing else has this type of problem.
- I was hoping someone maybe had an idea how I might get it fixed (or contact Onn).
- If you have any ideas of settings that I might be able to try, that would be good as well. I did try the settings under Sounds, but no luck so far.
- Also, if anyone knows what those particular apps have in common, that could help too. The following apps have no problems: Netflix, Disney+, HBO Max, and Vudu.
Thanks,
Josh
with my ONN device & TV for the past 2 days now on how to fix this problem.. I should of had Googled this problem before now.
