Sound pitch high occasionally
I'm posting this in Apple TV client since I think it is a playback issue, not a recording issue.
Sometimes when playing back recording content, and pausing, skipping, etc. the content will resume play with voices in a higher pitch. It is not quite a breathing helium effect, but somewhere between normal and that. Despite the pitch, playback is normal speed. I've tried changing to a different speed, then back to 1.0, but that doesn't seem to help.
I'm not 100% sure but it appears that if I exit Channels and stream some other content from another app, then go back to Channels, the problem is resolved.
I observed today when this happened, it was just after a glitch in reception caused minor pixilation. The sound immediately went higher pitched and stayed that way. Going back and replaying it again, the pixelation happened but this time the sound stayed normal.
