I'm pretty sure the answer is no, but I figured I'd ask just in case. Is there any way to configure a channel to failover to a different source if the quality goes below a set threshold?
Example/Use Case:
I get my local channels over the air via an HDHR Quatro. I also have an HDHR Prime, which also gets my local channels. My preference is to keep the Prime tuners open for cable channels and use the Quatro for locals, so I have the Quatro set as higher priority. But occasionally the signal quality from my antenna is lousy. I'd love to be able to tell Channels to automatically switch to the Prime if the Quatro signal quality goes below (to pick a number) 50%.
And the next question would be - If such a feature exists or becomes implemented, could it failover during mid stream so that there is minimal interruption?
