Sources won't load suddenly and no EPG
All of a sudden I didn't have any guide info, checked my server and I can't view my sources anymore, it's just constantly loading. Version says 2024.09.10.2115 and I'm not able to update. When I check for stable or pre-release it says "Up to Date!" but I know there are pre-release versions out. I'm running the server using docker compose with the latest tag.
What does your browser show when you go to this URL?
https://channels-dvr.s3.amazonaws.com/prerelease.json
{"version":"2024.11.13.1009","host":"https://cdn.channelsdvr.net/dvr"}
Try holding down your <SHIFT> key when clicking the Check for Update button
Sometimes after it updates, you have to refresh the browser to see it updated.
I just noticed that my vpn docker says it's unhealthy, I'm guessing it's that. Will update the thread.
Update: Yes that was the issue.
Thanks @chDVRuser for the suggestions.
