I am noticing on 41.2 Qubo and 41.3 ION Plus, both SD channels, and both are not that strong a signal...both are pausing, stuttering for several seconds, and then plays at a frame rate of like 1 fps for bit, then it recovers and plays good for a short time, then start up freezing again.
HDHR Quatro
The channels play smoothly despite the signal stats of
|Signal Strength|67%|
|Signal Quality|66%|
|Symbol Quality|100%|
They are not digitizing or breaking up like if dropped or low signal, they did before i got a better antenna and mount location.
The channels play smoothly in the HDHR app and via Emby.
Clients are Nvidia Shield 2019 Tube and Pro. Both hardwired.
Issue happens on both Beta ATV app version and Stable.
Server version at present: 2020.03.07.0019
I export a client log after a few min of the channel playing and it did the issue a few times.
I also notice that just before the stutters and 1fps thing happens, the seek bar Ui comes up and the thing jumps back in the time lime a few times then, jumps back to present, all by it self. I am not touching anything.
How do i Attach a .txt file?? The attach icon is not present on here (I am on other forum boards that use this same back end so i know it has a attach feature)
EDIT: I set Decoder to Software in the ATV app and that resolves the issue, but the picture is much more soft.
Here is log when using software:
https://pastebin.com/kt422SC9
EDIT2: I have set the app to Hybrid. And that seems to be good. Could you detail out what each mode is and how it works? How does Hybrid know when to use Hardware decode vs software? Is there any loss in video quality using anything other than Hardware?
The vast majority of channels we watch are HD, a few on OTA, but all others on on TVE. Does this decode setting affect TVE channels?
