Spectrum Login Issues
I had a system crash a while back and am now rebuilding things. I just reset up Channels on my Proxmox build in a LXC container. No issues there and Channels found my HDHomeRun device just fine.
But I can't seem to get TVEveryWhere to connect to my spectrum account. I enter my login information and then it just hangs, spinning on "Verifying Login on Spectrum"
I've tried rebooting a few times as well, but it just hangs there even after waiting over an hour.
Anyone have any thoughts or ideas to try? I know my username/pw is correct as I can log into spectrum without any problems.
Thanks,
PT
Edit. I think I may have an issue with chromium not installing correctly in a headless environment with no GUI. I don't remember that being an issue in the past, but its been a while since I had to touch anything. Trying to remember if needed to do anything special or not to get it going.
I'll try and report back if/when I get up and running. But any tips are appreciated.
Edit # 2.
This appears to likely be a Ubuntu 19 and Ubuntu 20 issue of some type and the installation of the chromium-browser failing. I setup a another LXC container in proxmox using Ubuntu 18. That install of chromium browser went fine, and then Channels logged in with no problem.
I haven't tried it on Ubuntu 19 yet though.
