I was aware that doing that clears the cache and I had updated password and then rescanned and it wasn’t working. Only after logging in to the links would it work. So excited to have 9 discovery channels at the same time. It has always limited to three even after the backend changed.
This solution worked for me as well: Updating the password in the Channels DVR server with the same password already in use
This fixed my issue as well. I also noticed that I'm no longer limited to 4 channels in this package, I can authenticate them all now. Added bonus to the backend change over I guess.
I'm having same problem but on my tv not internet tv. Where did food network channel go?
Did you try rescanning just that channel. What error displays there?
Re-authorizing Channels
I still have the channel using Xfinity on both my HDHR Prime tuner and Channels DVR TVE sources.
