Has anyone been able to log into Spectrum for TVE All I get is an error when trying to log into my account for Spectrum
Where are you located, and, do you know for sure that they support TVE?
Spectrum TVE working here in SoCal.
All is working fine here in North Carolina.
I am in Louisville Kentucky.
While a spectrum user. I don’t have spectrum internet currently.
Would this be an issue.
I am TiVo user a they are not fixing my cable card issue. So trying to see if this app could let me get back my ability to time shift tv.
No. Just login to your Spectrum account and you should get what you usually would get on your package (bar DRM'd channels)
I just get an error when adding spectrum in the TVE section of the DVR setup.
Try using your Spectrum credentials to login to a network live streaming site to see if it works.
Like https://go.cnn.com/ or https://www.nbc.com/live
If it gives an error and you don't know what it means, post the exact error message and someone should be able to help.
Yes spectrum account log ins work at those sites.
What is the error message?
