Just got my FireTV Stick 4k and installed Channels DVR...when starting the app, I just get the spinning wheel.
Is the screen white or purple?
Have you used any other streaming devices before with the DVR server?
Well working now...sat there for about 10 minutes, closed it and reopened...now working.
And now it is back to spinning wheel on purple screen
Do you have other devices that are working correctly?
It sounds like a bad WiFi connection. Is the DVR PC wired or on WiFi too?
DVR PC is Wired.
Just checked and phone is also doing the spinning wheel on purple background
Open the DVR web UI on your PC and see if the Log tab shows any errors.
First, thank you for your quick responses...that is awesome support.
Second, I have to head out to church, so I will work with this later.
Thanks again.
