TL;DR: Are there any more robust logs on the DVR to help pinpoint this issue?
Following up on this... and even more confused. I assumed there may be a network issue since all streams were being dropped at the same time. I hooked up an OTA HDHR and had it streaming during the same time the streams below failed. The OTA streams didn't drop once, leaving me to believe the issue is not with network routing.
Next guess is that the cable feed is dropping out, but that is also confusing. My home is served with fiber, the ONT has a cable output, I've never seen low signal levels on the cable feed and there was no downtime on the network. In addition, the dropped channels open back up without issue immediately after the DVR reports no data for 6 seconds.
At this point I'm not sure how to narrow down the problem. It could be an issue with the ONT. Is there any more logging that the DVR does that could help pinpoint the issue? Has the 6s timeout been in place for more than 2 months (when this first started). The only logs showing in the tuner are: 20220214-01:33:36 Tuner: tuner0 http stream ended (remote closed)
DVR 1:
2022/02/13 20:33:36.821654 [TNR] Cancelling stream 13225028/0 ch1106 after no data was received for 6s
2022/02/13 20:33:36.831314 [TNR] Closed connection to 13225028/0 for ch1106 NBCHD
2022/02/13 20:33:36.840462 [HLS] ffmpeg: ch1106-dANY-53f102099cdd-remux: Last message repeated 106 times
2022/02/13 20:33:37.029958 [SNR] Statistics for ch1106 NBCHD: ss=100% snq=100% seq=99%,0%-100% bps=18268248,0-19200064 pps=1563,0-1643
2022/02/13 20:33:38.002594 [HLS] Couldn't generate stream playlist for ch1106-dANY-53f102099cdd: Stream stopped
2022/02/13 20:33:38.002785 [HLS] Stopping transcoder session ch1106-dANY-53f102099cdd (out: 5h20m7.404989s, finished: true)
2022/02/13 22:08:25.653857 [TNR] Cancelling stream 13225028/0 ch1106 after no data was received for 6s
2022/02/13 22:08:25.653858 [TNR] Cancelling stream 13225028/1 ch1109 after no data was received for 6s
2022/02/13 22:08:25.672669 [HLS] ffmpeg: ch1106-dANY-53f102099cdd-remux: Last message repeated 32 times
2022/02/13 22:08:25.673581 [TNR] Closed connection to 13225028/0 for ch1106 NBCHD
2022/02/13 22:08:25.673673 [TNR] Closed connection to 13225028/1 for ch1109 PBS-A H
2022/02/13 22:08:25.685456 [SNR] Statistics for "TV/Vienna Blood/Vienna Blood S02E00 Darkness Rising Part 2 2022-02-13-2200.mpg": ss=100% snq=100% seq=100% bps=10047979,1570176-19055680 pps=851,0-1631
2022/02/13 22:08:25.702592 [DVR] Job 1644807600-107 Vienna Blood ended prematurely: 51m34.297412439s
2022/02/13 22:08:25.775113 [DVR] Starting job 1644807600-107 Vienna Blood on ch=[1109 1107 113]
2022/02/13 22:08:25.775245 [DVR] Waiting 18h51m34.224757714s until next job 1644876000-35 The Five
2022/02/13 22:08:25.834726 [SNR] Statistics for ch1106 NBCHD: ss=100% snq=100% seq=100% bps=18671205,1186656-19183520 pps=1597,0-1641
2022/02/13 22:08:25.939985 [HLS] Couldn't generate stream playlist for ch1106-dANY-53f102099cdd: Stream stopped
2022/02/13 22:08:25.940153 [HLS] Stopping transcoder session ch1106-dANY-53f102099cdd (out: 1h33m43.383878s, finished: true)
DVR 2:
2022/02/13 20:33:36.823087 [TNR] Cancelling stream 1317E539/0 ch1106 after no data was received for 6s
2022/02/13 20:33:36.841581 [TNR] Closed connection to 1317E539/0 for ch1106 NBCHD
2022/02/13 20:33:36.846690 [HLS] ffmpeg: ch1106-dANY-6d4429b91688-remux: Last message repeated 49 times
2022/02/13 20:33:37.040459 [SNR] Statistics for ch1106 NBCHD: ss=100% snq=100% seq=100% bps=18444571,112800-19172992 pps=1578,0-1641
2022/02/13 20:33:38.060885 [HLS] Couldn't generate stream playlist for ch1106-dANY-6d4429b91688: Stream stopped
2022/02/13 20:33:38.060932 [HLS] Stopping transcoder session ch1106-dANY-6d4429b91688 (out: 2h54m16.585s, finished: true)
2022/02/13 22:08:25.654119 [TNR] Cancelling stream 1317E539/0 ch1106 after no data was received for 6s
2022/02/13 22:08:25.676607 [TNR] Closed connection to 1317E539/0 for ch1106 NBCHD
2022/02/13 22:08:25.681514 [HLS] ffmpeg: ch1106-dANY-6d4429b91688-remux: Last message repeated 32 times
2022/02/13 22:08:25.853966 [SNR] Statistics for ch1106 NBCHD: ss=100% snq=100% seq=100% bps=18674377,9303744-19157952 pps=1597,0-1641
2022/02/13 22:08:26.426006 [HLS] Couldn't generate stream playlist for ch1106-dANY-6d4429b91688: Stream stopped
2022/02/13 22:08:26.426109 [HLS] Stopping transcoder session ch1106-dANY-6d4429b91688 (out: 1h33m26.903378s, finished: true)
DVR 3:
2022/02/13 20:33:36.821914 [TNR] Cancelling stream 131C093A/0 ch1106 after no data was received for 6s
2022/02/13 20:33:36.822985 [TNR] Closed connection to 131C093A/0 for ch1106 NBCHD
2022/02/13 20:33:36.839695 [HLS] ffmpeg: ch1106-dANY-70c3cc511d48-remux: Last message repeated 43 times
2022/02/13 20:33:37.031486 [SNR] Statistics for ch1106 NBCHD: ss=100% snq=100% seq=100% bps=18414741,9956480-19157952 pps=1575,0-1641
2022/02/13 20:33:38.012081 [HLS] Couldn't generate stream playlist for ch1106-dANY-70c3cc511d48: Stream stopped
2022/02/13 20:33:38.012131 [HLS] Stopping transcoder session ch1106-dANY-70c3cc511d48 (out: 2h30m18.782567s, finished: true)
2022/02/13 22:08:25.655118 [TNR] Cancelling stream 131C093A/0 ch1106 after no data was received for 6s
2022/02/13 22:08:25.681513 [TNR] Closed connection to 131C093A/0 for ch1106 NBCHD
2022/02/13 22:08:25.687912 [HLS] ffmpeg: ch1106-dANY-70c3cc511d48-remux: Last message repeated 32 times
2022/02/13 22:08:25.739395 [HLS] Couldn't generate stream playlist for ch1106-dANY-70c3cc511d48: Stream stopped
2022/02/13 22:08:25.739708 [HLS] Stopping transcoder session ch1106-dANY-70c3cc511d48 (out: 1h34m17.944922s, finished: true)
2022/02/13 22:08:25.746580 [SNR] Statistics for ch1106 NBCHD: ss=100% snq=100% seq=99%,0%-100% bps=18675861,0-19157952 pps=1597,0-1641
