Change the IP address and port to match your server
curl -XPUT http://127.0.0.1:8089/updater/check/2024.11.10.2341
Of course, when the next stable release comes out, it will auto update to it.
@bnhf maybe this could be added to OliveTin.
Or maybe not. See Start live detection when watching in-progress recording not working - #29 by chDVRuser
command line / terminal, etc.
Windows command prompt, Mac terminal, Linux command line.
Anything on your network, including your dvr server.
curl is a command line utility
I entered this in terminal and i just get the response
true%
If you used the IP address and port of your dvr server, it should have loaded v2024.11.10.2341
Check the version or look at the dvr log.
It did nothing, it isn't in the log
Guess they fixed it so you cannot load an older version that way then.
If you revert back to the latest stable version (2024.09.10.2115) and then run that curl command it should work to update it to v2024.11.10.2341.
How do I revert back to a stable version? LoL
This is probably the easiest way
Instead of worrying about Live detection I would look to move away from the Shield ASAP.... Never know the next release might kill it.
You want to pay for new hardware for me? So easy for someone to say when you don't know what my situation is.
The issue isn't just live detection. Even after recording it is happening.
Anyways, I'll move back to my QNAP server since OTA DVR and Commercial skipping are my primary concern over TVE.
I switched back to my QNAP and the Recordings I currently have didn't get commercial detection.
I tried to re-run it and it fails with an error 43.
2024/11/24 17:27:51.983102 [DVR] Running commercial detection on file 229 (TV/Blue Bloods/Blue Bloods S14E16 The Gray Areas 2024-11-22-2159.mpg)
2024/11/24 17:27:52.386153 [DVR] Commercial detection failed for Blue Bloods S14E16 The Gray Areas 2024-11-22-2159.mpg: exit status 43: Comskip 0.82.011, made using ffmpeg
Donator build
