I have The "Channels DVR Server" image installed on my Raspberry Pi 4.
I used SSH to install pluto-for-channels in docker which is pre-installed on the server. It works great when started, it even though is configured to restart "always" it does not start when booted and I have to manually start the container from the command line. Is there a way for it to start on boot. Thank you.
It should work if you update the OS by click-and-hold on the Check for Update button.
That did the job. Thank you for providing a solution so quickly!
