How do you enable it on the new beta?
Edit: is it only for imported media? I don’t have any, I want it for TVE since the server won’t show the stats.
Swipe down in the player.
I see no difference. All I see is the quick guide like normal and language.
How do you enable it on iOS? Swipe down does nothing. Thanks.
Same. Don't see anything different (AppleTV). Also can't find the Sleep Option....
Wrong build went out. Re-uploading now.
Apple is having issues with TestFlight or something. Hopefully it should be up soon.
FYI: this is only in tvOS right now.
It’s out!
Swipe down in the video player to get to the new options.
You can also use the I key to toggle stats, so you can map it to your remote with our new advanced remote features.
hope this comes to android version,
Yes, as previously mentioned:
Oops, my bad. Missed that.
New build is out, with this available iOS now too.
