-- Save as Application with "Stay open after run handler" checked
property threshold : 25
property agentLabel : "com.getchannels.dvr"
on idle
set battInfo to do shell script "pmset -g batt"
if battInfo contains "Battery Power" then
set pct to (do shell script "pmset -g batt | grep -Eo '[0-9]+%' | head -1 | tr -d '%'") as integer
if pct ≤ threshold then
do shell script "launchctl bootout gui/$(id -u)/" & agentLabel & " 2>/dev/null; pkill -x channels-dvr; true"
display notification "Battery at " & pct & "%, Channels DVR stopped" with title "Battery Guard"
quit
end if
end if
return 60 -- check every 60s
end idle
property threshold : 50
on idle
if pct ≥ threshold then
set isRunning to (do shell script "pgrep -x channels-dvr >/dev/null && echo yes || echo no")
if isRunning is "no" then
do shell script "launchctl bootstrap gui/$(id -u) \"$HOME/Library/LaunchAgents/" & agentLabel & ".plist\" 2>/dev/null; launchctl kickstart gui/$(id -u)/" & agentLabel & " 2>/dev/null; true"
display notification "Battery at " & pct & "%, Channels DVR restarted" with title "Battery Guard"
end if
quit
end if
end idle
Something like this maybe. Unload the plst and then kill the process for good measure if the battery threshold hits 25%, and then if it reaches 50%, reload the plist.
