[sent an email to [email protected] about a week ago and have heard nothing, so...]
I am using the following equipment:
HDHomeRun Flex 4K is the video/audio source
Nvidia Shield Pro running the Channels DVR being fed by the HDHomeRun
Trinnov Altitude 16 audio processor being fed by the Nvidia Shield
Lumagen Pro video processor being fed video by the Trinnov
JVC projector fed by the Lumagen pro
I do not turn off the HDHomeRun or the Nvidia Shield, so these are always active
What’s odd is that after turning off the Trinnov audio processor, Lumagen Pro, and JVC - and then turning on all of these again, the sound level of the system is quite a bit higher than when I turn it off.
If I use the Nvidia Shield’s remote to open the guide via the Back Button and then return to the same channel, the sound level drops quite a bit.
If, instead I use the remote’s D-pad to show the Quick Guide of my channels and pick another channel the sound level remains the same.
I don’t think there are any means for controlling any of this in Channels DVR or the Nvidia Shield Pro. And there is really nothing in the Trinnov that is being done.
Any ideas???
