I can't pin point when it exactly cuts out but I like to have it on in the background. I wake up and the stream usually has an error and had stopped working.
Here are logs from the dvr. I don't know if they'll be much help.
2148980540, current: -2147483648; changing to 2148980541. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980541, current: -2147483648; changing to 2148980542. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980542, current: -2147483648; changing to 2148980543. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980543, current: -2147483648; changing to 2148980544. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980544, current: -2147483648; changing to 2148980545. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980545, current: -2147483648; changing to 2148980546. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980546, current: -2147483648; changing to 2148980547. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980547, current: -2147483648; changing to 2148980548. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980548, current: -2147483648; changing to 2148980549. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980549, current: -2147483648; changing to 2148980550. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980550, current: -2147483648; changing to 2148980551. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980551, current: -2147483648; changing to 2148980552. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980552, current: -2147483648; changing to 2148980553. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980553, current: -2147483648; changing to 2148980554. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980554, current: -2147483648; changing to 2148980555. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980555, current: -2147483648; changing to 2148980556. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980556, current: -2147483648; changing to 2148980557. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980557, current: -2147483648; changing to 2148980558. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980558, current: -2147483648; changing to 2148980559. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980559, current: -2147483648; changing to 2148980560. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980560, current: -2147483648; changing to 2148980561. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980561, current: -2147483648; changing to 2148980562. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980562, current: -2147483648; changing to 2148980563. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980563, current: -2147483648; changing to 2148980564. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980564, current: -2147483648; changing to 2148980565. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980565, current: -2147483648; changing to 2148980566. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980566, current: -2147483648; changing to 2148980567. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980567, current: -2147483648; changing to 2148980568. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980568, current: -2147483648; changing to 2148980569. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980569, current: -2147483648; changing to 2148980570. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980570, current: -2147483648; changing to 2148980571. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980571, current: -2147483648; changing to 2148980572. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980572, current: -2147483648; changing to 2148980573. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980573, current: -2147483648; changing to 2148980574. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980574, current: -2147483648; changing to 2148980575. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980575, current: -2147483648; changing to 2148980576. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980576, current: -2147483648; changing to 2148980577. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980577, current: -2147483648; changing to 2148980578. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980578, current: -2147483648; changing to 2148980579. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980579, current: -2147483648; changing to 2148980580. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980580, current: -2147483648; changing to 2148980581. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980581, current: -2147483648; changing to 2148980582. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980582, current: -2147483648; changing to 2148980583. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980583, current: -2147483648; changing to 2148980584. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980584, current: -2147483648; changing to 2148980585. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980585, current: -2147483648; changing to 2148980586. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980586, current: -2147483648; changing to 2148980587. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980587, current: -2147483648; changing to 2148980588. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980588, current: -2147483648; changing to 2148980589. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980589, current: -2147483648; changing to 2148980590. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980590, current: -2147483648; changing to 2148980591. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980591, current: -2147483648; changing to 2148980592. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980592, current: -2147483648; changing to 2148980593. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980593, current: -2147483648; changing to 2148980594. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980594, current: -2147483648; changing to 2148980595. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980595, current: -2147483648; changing to 2148980596. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980596, current: -2147483648; changing to 2148980597. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980597, current: -2147483648; changing to 2148980598. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980598, current: -2147483648; changing to 2148980599. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980599, current: -2147483648; changing to 2148980600. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980600, current: -2147483648; changing to 2148980601. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980601, current: -2147483648; changing to 2148980602. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980602, current: -2147483648; changing to 2148980603. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980603, current: -2147483648; changing to 2148980604. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980604, current: -2147483648; changing to 2148980605. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980605, current: -2147483648; changing to 2148980606. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980606, current: -2147483648; changing to 2148980607. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980607, current: -2147483648; changing to 2148980608. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980608, current: -2147483648; changing to 2148980609. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980609, current: -2147483648; changing to 2148980610. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980610, current: -2147483648; changing to 2148980611. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980611, current: -2147483648; changing to 2148980612. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980612, current: -2147483648; changing to 2148980613. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980613, current: -2147483648; changing to 2148980614. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980614, current: -2147483648; changing to 2148980615. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980615, current: -2147483648; changing to 2148980616. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980616, current: -2147483648; changing to 2148980617. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980617, current: -2147483648; changing to 2148980618. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980618, current: -2147483648; changing to 2148980619. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980619, current: -2147483648; changing to 2148980620. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980620, current: -2147483648; changing to 2148980621. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980621, current: -2147483648; changing to 2148980622. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980622, current: -2147483648; changing to 2148980623. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980623, current: -2147483648; changing to 2148980624. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980624, current: -2147483648; changing to 2148980625. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980625, current: -2147483648; changing to 2148980626. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980626, current: -2147483648; changing to 2148980627. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980627, current: -2147483648; changing to 2148980628. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980628, current: -2147483648; changing to 2148980629. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980629, current: -2147483648; changing to 2148980630. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980630, current: -2147483648; changing to 2148980631. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980631, current: -2147483648; changing to 2148980632. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980632, current: -2147483648; changing to 2148980633. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980633, current: -2147483648; changing to 2148980634. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980634, current: -2147483648; changing to 2148980635. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980635, current: -2147483648; changing to 2148980636. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980636, current: -2147483648; changing to 2148980637. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980637, current: -2147483648; changing to 2148980638. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980638, current: -2147483648; changing to 2148980639. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980639, current: -2147483648; changing to 2148980640. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980640, current: -2147483648; changing to 2148980641. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980641, current: -2147483648; changing to 2148980642. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980642, current: -2147483648; changing to 2148980643. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980643, current: -2147483648; changing to 2148980644. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980644, current: -2147483648; changing to 2148980645. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980645, current: -2147483648; changing to 2148980646. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980646, current: -2147483648; changing to 2148980647. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980647, current: -2147483648; changing to 2148980648. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980648, current: -2147483648; changing to 2148980649. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980649, current: -2147483648; changing to 2148980650. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980650, current: -2147483648; changing to 2148980651. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980651, current: -2147483648; changing to 2148980652. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980652, current: -2147483648; changing to 2148980653. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980653, current: -2147483648; changing to 2148980654. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980654, current: -2147483648; changing to 2148980655. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980655, current: -2147483648; changing to 2148980656. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980656, current: -2147483648; changing to 2148980657. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980657, current: -2147483648; changing to 2148980658. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980658, current: -2147483648; changing to 2148980659. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980659, current: -2147483648; changing to 2148980660. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980660, current: -2147483648; changing to 2148980661. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980661, current: -2147483648; changing to 2148980662. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980662, current: -2147483648; changing to 2148980663. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980663, current: -2147483648; changing to 2148980664. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980664, current: -2147483648; changing to 2148980665. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980665, current: -2147483648; changing to 2148980666. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980666, current: -2147483648; changing to 2148980667. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980667, current: -2147483648; changing to 2148980668. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980668, current: -2147483648; changing to 2148980669. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980669, current: -2147483648; changing to 2148980670. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980670, current: -2147483648; changing to 2148980671. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980671, current: -2147483648; changing to 2148980672. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980672, current: -2147483648; changing to 2148980673. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980673, current: -2147483648; changing to 2148980674. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980674, current: -2147483648; changing to 2148980675. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980675, current: -2147483648; changing to 2148980676. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980676, current: -2147483648; changing to 2148980677. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980677, current: -2147483648; changing to 2148980678. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980678, current: -2147483648; changing to 2148980679. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980679, current: -2147483648; changing to 2148980680. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980680, current: -2147483648; changing to 2148980681. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980681, current: -2147483648; changing to 2148980682. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980682, current: -2147483648; changing to 2148980683. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980683, current: -2147483648; changing to 2148980684. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980684, current: -2147483648; changing to 2148980685. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980685, current: -2147483648; changing to 2148980686. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980686, current: -2147483648; changing to 2148980687. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980687, current: -2147483648; changing to 2148980688. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980688, current: -2147483648; changing to 2148980689. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980689, current: -2147483648; changing to 2148980690. This may result in incorrect timestamps in the output file.
[hls @ 000000000291de80] Non-monotonous DTS in output stream 0:0; previous: 2148980690, current: -2147483648; changing to 2148980691. This may result in incorrect timestamps in the output file.
