Stream Link for MS NOW?
Anyone figured out the stream link for MSNOW? Can't find a solution since the change.
Thanks
Which device are you using? For me I use msnbctve for Apple TV and msnow for iPhone and iPad. I use 2 channel numbers
Using Apple tv. Got it working.:+1:
Having a hard time. Can you copy your text input? Do any of the settings below the text field need to be imputed?
This works on my Apple TV:
#EXTINF:-1 channel-id="msnbc" tvg-chno="6050" tvc-guide-stationid="64241",MSNBC
msnbctve://live/msnbc
You've already found the original setup guide? Experimental: Stream Links from the Guide via Custom Channels
I don't think the Options or Guide data needs changing, but I don't remember.
