Stream Link Manager (Work in Progress)
After starting to play around with getting a clean conversion from Hulu to Disney+ as part of the merger of the apps, I began to kick around the idea of something much bigger: a Stream Link Manager. The idea is this:
  • Locally run program that has a web-based front-end interface (maybe Docker, maybe executable?)
  • In the interface, user selects which streaming services they have access to and puts them into a preference order
  • In the interface, user searches for a program (movie or TV Show)
  • User bookmarks program for consumption
  • Interface uses the API of an existing management system, preferably JustWatch
  • JustWatch returns the URLs of the programs
  • Interface creates and manages .strmlnk files in the appropriate Channels directory. Once per day or hour or some other user selected interval, the Interface will check the existing management system to see if the program is available on one of the user defined streaming services. If it is on multiple, it will go with the one with the highest preference order.
    • If the program changes streaming services, the .strmlnk will automatically update
    • If the program is no longer available on any streaming service the user has selected, it will delete the .strmlnk file
  • Channels already scans for media updates on a user defined schedule. However, will need to automate running an automatic prune (user choice if desired, just in case)
  • If a user deletes a program in Channels, an API call will have to check for this and remove from the program from the Interface so the .strmlnk is not recreated.
See: High Level Flow Diagram below...
So, fairly complicated in the solution acting as a middleman between two disparate systems. As such, I've decided to approach this piecemeal, getting bits working at a time. Below I will place each stand-alone component so they can be run individually without the interface in general. The current components consist of:
This Python script will allow a user to create all the necessary .strmlnk files for a TV Show. It does not add the URL content to the files; it just creates all the directories and necessary files.
Name this something like below. It doesn't matter where you put it.
ProtoType_Stream_Link_File_Creator.py
import os
import sys
import datetime
# Check if the OS allows popup boxes
try:
    import tkinter as tk
    from tkinter import filedialog
    from tkinter import simpledialog
    from tkinter import messagebox
    from tkinter import Tk
except ImportError:
    # If popup boxes are not allowed, do not import tkinter
    pass
def current_time():
    return datetime.datetime.now().strftime("%Y-%m-%d %H:%M:%S.%f") + ": "
def get_directory():
    """Get a directory path from the user using a file dialog or command line."""
    if os.name == "posix":  # Unix-like systems (including macOS)
        directory_path = input("Enter a directory path: ")
    else:
        try:
            root = tk.Tk()
            root.withdraw()  # Hide the main window
            directory_path = filedialog.askdirectory(title="Select a base directory")
        except ImportError:
            print("Error: tkinter is not available. Please enter the directory path manually.")
    return directory_path
def get_user_input(prompt):
    """Get user input from a popup box or command line."""
        user_input = input(prompt)
    else:
        try:
            from tkinter import simpledialog, messagebox
            root = tk.Tk()
            user_input = simpledialog.askstring("Input", prompt)
            root.destroy()  # Close the pop-up window
        except ImportError:
            print("Error: tkinter is not available. Please enter the input manually.")
    return user_input.strip()  # Remove leading/trailing spaces
def get_radio_selection(prompt, options):
    """Get user selection from radio buttons or command line."""
        print(prompt)
        for i, option in enumerate(options, start=1):
            print(f"{i}. {option}")
        while True:
            try:
                choice = int(input("Enter the number corresponding to your choice: "))
                if 1 <= choice <= len(options):
                    return options[choice - 1]
                else:
                    print("Invalid choice. Please try again.")
            except ValueError:
                print("Invalid input. Please enter a valid number.")
    else:
        try:
            root = tk.Tk()
            # Create a dialog box with radio buttons for each option
            dialog = tk.Toplevel(root)
            dialog.title("Select a Prefix Option")
            # Calculate the height of the dialog based on the number of options
            dialog_height = 150 + len(options) * 30
            dialog.geometry(f"300x{dialog_height}")
            # Add the prompt to the dialog
            tk.Label(dialog, text=prompt).pack()
            # Create a variable to store the selected option
            selected_option = None
            def select_option(option):
                nonlocal selected_option
                selected_option = option
                dialog.destroy()
            for option in options:
                tk.Button(dialog, text=option, command=lambda o=option: select_option(o)).pack()
            # Wait for the user to select an option
            dialog.wait_window()
            # Return the selected option
            return selected_option
        except ImportError:
            return input(prompt)
def create_directory(directory_path):
    """Create a directory if it doesn't exist."""
    if not os.path.exists(directory_path):
        os.makedirs(directory_path)
def create_season_folders(base_directory, starting_season, ending_season):
    """Create season folders with proper naming."""
    for season_number in range(starting_season, ending_season + 1):
        season_folder_name = f"Season {season_number:02}"
        season_folder_path = os.path.join(base_directory, season_folder_name)
        create_directory(season_folder_path)
def create_episode_files(season_folder, episode_count, prefix):
    """Create episode files within a season folder."""
    for episode_number in range(1, episode_count + 1):
        episode_name = f"S{season_folder[-2:]}E{episode_number:02}"
        if prefix != "None":
            episode_name = f"{prefix} {episode_name}"
        episode_name += ".strmlnk"
        episode_file_path = os.path.join(season_folder, episode_name)
        if not os.path.exists(episode_file_path):
            open(episode_file_path, 'w').close()
def main():
    base_directory = get_directory()
    series_name_year = get_user_input("Enter the Series Name (Year): ")
    prefix_options = ["None", "(DUB)", "(SUB)"]
    selected_prefix = get_radio_selection("Select a Prefix Option:", prefix_options)
    starting_season = int(get_user_input("Enter the Starting Season Number: "))
    ending_season = int(get_user_input("Enter the Ending Season Number: "))
    create_directory(os.path.join(base_directory, series_name_year))
    create_season_folders(os.path.join(base_directory, series_name_year), starting_season, ending_season)
        season_folder_path = os.path.join(base_directory, series_name_year, season_folder_name)
        episode_count = int(get_user_input(f"Number of Episodes for {season_folder_name}: "))
        create_episode_files(season_folder_path, episode_count, selected_prefix)
    print(f"{current_time()} Directory structure and files created successfully!")
if __name__ == "__main__":
    main()
Running the code, the user will be prompted to select a base directory where they want the program to go. This should be somewhere under the Imports\TV directory, either directly or a management folder.
After selecting that, the user then enters the program name, preferably in the format PROGRAM (YEAR). If they happen to put in some extra spaces at the beginning or the end, this will automatically clear them out, so no issue.
JP_ScreenShot_2024_04_01_11_22_28
Normally, the format of the resulting Stream Link file will be something like "S01E01.strmlnk". However, there is an option to add a Prefix. In this version of the code, the user can select between having nothing, "(DUB)" or "(SUB)", which I find useful for Hulu/Disney+ that separates programs this way instead of having you select a language in the interface.
JP_ScreenShot_2024_04_01_11_22_42
At this point, the user enters the starting and ending Season numbers. This will create folders for those Seasons and everything in between.
JP_ScreenShot_2024_04_01_11_23_05
JP_ScreenShot_2024_04_01_11_23_22
They will then be prompted to enter in the number of Episode per Season.
JP_ScreenShot_2024_04_01_11_23_37
JP_ScreenShot_2024_04_01_11_23_54
That is all the information that is needed. A folder will be created with the entered program name and separate ones for all the Seasons. Note that if the Season or Episode number is a single digit, it will create it with a leading zero. If the Season or Episode number already exists, it does not recreate it, but instead just moves on.
JP_ScreenShot_2024_04_01_11_24_48
At this point, all the files exist and the user can edit them to put in the appropriate URL and do the rest of the normal process.
JP_ScreenShot_2024_04_01_11_25_09
Also, in case you are on a system that does not allow popup boxes, you will go through the same process on a command line intead:
Please be advised that I have only tested this in Windows and WSL (Ubuntu). I would appreciate if someone with a Mac or pure Linux setup would test and see if you have any additional issues so that I can address them.
This is a cool project. I'm using Windows too.
I'm not sure I understand the use of the prefix, DUB or SUB.
Is DUB for "dubbed," meaning originally in a different language other than English?
Is SUB for "subtitled", meaning the episode is in a foreign language and contains forced English subtitles on the screen?
Yes
Spot on. Think of it this way: Hulu/Disney+ has many foreign language programs. Season 1 may be available both as dubbed and subtitled, but Season 2 is only subtitled. But then three months later the dubbed version of Season 2 becomes available. Thus originally I would create the show with all episodes, including the Subtitled version for Season 2. However, I would then replace them with the dubbed version, which is my personal preference. So I use the Prefix to tell me which version my Stream Link is pointing to.
If the script will support command line arguments, I can give it the "OliveTin treatment" and add it as an OliveTin Action. How's that sound? :slight_smile:
Well, this is like Day 1 pre-Alpha, so I wouldn't recommend jumping the gun just yet!
No worries on that. Mostly I just wanted to check that you're planning to support command line arguments in addition to pop-up boxes.
Well, the end goal is to have a web interface with minimal human intervention, so the final product wouldn't even use popups and things to enter like this. My intention for the interim, though, is to release various stand-alone components as I work through them. File creation is one of the more annoying aspects of Stream Links, so I thought it would make a good singular piece to release.
That all said, I have modified the code above so that it will use popup boxes if it can, otherwise it will use command lines, so it's all good now:
If I’m understanding the end goal of this project correctly - I am very excited for it to get off the ground.
Will it work like:
  • Open program
  • Select streaming service
  • Search (eg “Marvel”)
  • Tick movies you want to add
  • Automatically gets added to channels server
What services are you hoping to have on this?
I thought I'd give this a whirl in OliveTin, so you can see what it would be like. Since you're not supporting passing arguments in a single command in your Python script, and Bash is super-easy for this kind of thing, I also made a couple of changes to see if they meet your goals.
I set it up to match the series name, and first airing year, with a query to the TVMaze API. This will pull the JSON data for the all season and episode data for that series, and create files in the same location you demo'd.
Here's what it looks like:
screenshot-htpc6-2024.04.02-19_01_26
Here's the script:
#!/bin/bash
set -x
# Global variables
dvr="$1"
channelsHost=$(echo $dvr | awk -F: '{print $1}')
channelsPort=$(echo $dvr | awk -F: '{print $2}')
dvrShare=/mnt/$channelsHost-$channelsPort/Imports/TV/Hulu
showName=$(echo "$2" | sed -e 's/\b\(.\)/\u\1/g' -e 's/ /%20/g')
showYear="\"$3\""
episodePrefix="$4"
  [[ "$episodePrefix" == "none" ]] && episodePrefix=""
# TVMaze API calls and post jq variable format changes
showID=$(curl -s "http://api.tvmaze.com/search/shows?q=$showName" | jq '.[] | select(.show.premiered | startswith('$showYear')).show.id')
episodeList=$(curl -s "http://api.tvmaze.com/shows/$showID/episodes" | jq -r '.[] | "S\((if .season < 10 then "0" else "" end) + (.season | tostring))E\((if .number < 10 then "0" else "" end) + (.number | tostring))"')
showName=$(echo "$showName" | sed 's/%20/ /g')
showYear=$(echo "$showYear" | sed 's/"//g')
[[ -n $episodePrefix ]] && episodePrefix="($episodePrefix) "
# Episode list to array and streamlink file creation
mapfile -t episodeArray <<< "$episodeList"
for episode in "${episodeArray[@]}"; do
  seasonNumber="Season ${episode:1:2}"
  mkdir -p "$dvrShare/$showName ($showYear)/$seasonNumber"
  touch "$dvrShare/$showName ($showYear)/$seasonNumber/$episodePrefix$episode.strmlnk" \
    && echo Confirmed or added: "$dvrShare/$showName ($showYear)/$seasonNumber/$episodePrefix$episode.strmlnk"
done
This will run on any system with OliveTin properly installed, from anywhere on one's LAN or Tailnet. Output can be directed to the DVR_SHARE for however many Channels DVRs are configured in OliveTin. Mostly a proof of concept for you at this point, let me know what you think. :slight_smile:
More like this:
  1. Open Program
  2. Provider Controls
    -- Select Streaming Services
    -- Set priority order for Streaming Services
    -- Should have the ability to have all of them (or whatever the backend management service like JustWatch has available).
  3. Pick Programs and Availability
    -- Search (e.g., "Hot Tub Time Machine")
    -- Tick program you want to add (or, in the case of TV shows, pick the season [All, specific, only new])
    -- Also have the ability to create a manual entry in case the underlying database does not have a record.
  4. Stream Link Generator
    -- IF the Program is available on a selected Streaming Service, create the .strmlnk file ("Hot Tub Time Machine (2010).strmlnk")
    -- Using the priority order for Streaming Services, get the direct link to the program ( Hoopla > Netflix, therefore, use Hoopla Stream Link)
    -- IF it is a manual program, just create the .strmlnk
  5. Monitor
    -- IF the Program becomes available on a higher priority Streaming Service, replace the contents of the .strmlnk file with that Stream Link.
    -- IF the Program changes to not available on any selected Streaming Services, delete the .strmlnk file and run the Channels Prune operation (user option whether to allow this last step to happen automatically or not).
    -- IF the Program is currently not available on any selected Streaming Services, but then becomes available, run the Stream Link Generator process from above on it.
    -- IF the Program is deleted in Channels, remove the Tick for the Program in the interface so that the .strmlnk file is not automatically created.
No, that would break functionality. There are many use cases where either the Streaming Service does not have all episodes or the user only wants some because they've seen the others. Or maybe they only want new episodes when they become available. Interactivity and user selection is a requirement. The method for interactivity is still in the design phase. See the post above this one for more details.
Thanks, but what I've put out so far is about 2% of what the real Stream Link Manager is intended to do. I'm sure it will make a fine OliveTin deployment in the future, but for now, I'm just taking an open agile development approach with proof of concept components. For the foreseeable future, it would not be worth your time to try to take anything I've done or am doing and migrate it over, even for proof of concept. Too much is in flux and not anywhere near a final product.
ProtoType_Stream_Link_Maker.py
import os
import re
import urllib.parse
import datetime
def current_time():
# Install simple-justwatch-python-api (https://github.com/Electronic-Mango/simple-justwatch-python-api) if not already installed
try:
    from simplejustwatchapi.justwatch import search, details
except ImportError:
        os.system("pip3 install simple-justwatch-python-api")
    else:
        os.system("pip install simple-justwatch-python-api")
try:
except ImportError:
    pass
# Get a directory path from the user using a file dialog or command line.
    while True:
        else:
            try:
                root = tk.Tk()
            except ImportError:
        # Validate if a value was entered
        if directory_path:
            break
        else:
            print(f"{current_time()} Error: Please provide a valid directory path.")
    print("")
    print(f"{current_time()} Chosen Directory: {directory_path}")
    print("")
# Get user input from a popup box or command line.
    while True:
        else:
            try:
                root = tk.Tk()
            except ImportError:
        if user_input is not None and user_input.strip():
        else:
            print(f"{current_time()} Error: Please provide a valid input.")
# Get user selection from buttons or command line list.
def get_button_selection(prompt, options):
    while True:
            print(prompt)
            try:
                else:
            except ValueError:
        else:
            try:
                root = tk.Tk()
                dialog.title("Select an Option")
                    dialog.destroy()
                if selected_option:
                else:
                    print(f"{current_time()} Error: Please select an option.")
            except ImportError:
# Remove invalid characters (e.g., colons, slashes, etc.)
def sanitize_name(name):
    sanitized = re.sub(r'[\\/:*?"<>|]', '', name)
    return sanitized
# Create a directory if it doesn't exist.
# Create season folders with proper naming.
# Create episode files within a season folder.
def create_episode_files(season_folder, episode_count, prefix, episode_url):
        print(f"{current_time()} Creating: {episode_file_path}")
            with open(episode_file_path, 'w') as file:
                file.write(episode_url)
# Create movie files
def create_movie_file(movie_directory, movie_name_base, movie_url):
    movie_name = f"{movie_name_base}"
    movie_name += ".strmlnk"
    movie_file_path = os.path.join(movie_directory, movie_name)
    print(f"{current_time()} Creating: {movie_file_path}")
    if not os.path.exists(movie_file_path):
        with open(movie_file_path, 'w') as file:
            file.write(movie_url)
# Find all the Streaming Services for the selected Program
def extract_offer_info(offers):
    result = []
    for offer in offers:
        name = offer.package.name
        price_string = offer.price_string if offer.price_string is not None else "$0.00"
        url = urllib.parse.unquote(offer.url)  # Decode the URL
        result.append({"name": name, "price_string": price_string, "url": url})
    return result
# Input the country code to search
def get_country_code():
    while True:
        country_code_input = input("Enter a 2-letter country code (or press Enter for default 'US'): ")
        if not country_code_input:
            return "US"  # Default value
        elif len(country_code_input) == 2 and country_code_input.isalpha():
            return country_code_input.upper()
        else:
            print("")
            print("Invalid input. Please enter a valid 2-letter country code.")
            print("")
# Input the language code to search
def get_language_code():
    while True:
        language_code_input = input("Enter a 2-letter language code (or press Enter for default 'en'): ")
        if not language_code_input:
            return "en"  # Default value
        elif len(language_code_input) == 2 and language_code_input.isalpha():
            return language_code_input.lower()
        else:
            print("")
            print("Invalid input. Please enter a valid 2-letter language code.")
            print("")
# Input the number of search results to return
def get_num_results():
    while True:
        try:
            num_results_input = input("Enter the number of search results (or press Enter for default '9'): ")
            if not num_results_input:
                return 9  # Default value
            num_results = int(num_results_input)
            if num_results > 0:
                return num_results
            else:
                print("")
                print("Please enter a positive integer.")
                print("")
        except ValueError:
            print("")
            print("Invalid input. Please enter a valid positive integer.")
            print("")
# Main Function
def main():
    print("")
    country_code = get_country_code()
    print("")
    print(f"{current_time()} Selected country code: {country_code}")
    print("")
    language_code = get_language_code()
    print("")
    print(f"{current_time()} Selected language code: {language_code}")
    print("")
    num_results = get_num_results()
    print("")
    print(f"{current_time()} Selected number of search results: {num_results}")
    print("")
    # Loop to run again
    while True:
        # Search for a program
        while True:
            print("")
            program_search = input("Enter the program to search for: ")
            program_search_base = search(program_search, country_code, language_code, num_results, True)
            # Extract the titles, release years, and object types from the response
            program_search_results = [(entry.title, entry.release_year, entry.object_type, entry.entry_id) for entry in program_search_base]
            # Display a list of options to the user
            print("")
            print("Select an option (or enter 0 to cancel and retry):")
            print("")
            for i, (title, release_year, object_type, entry_id) in enumerate(program_search_results, start=1):
                print(f"{i}. {title} ({release_year}) | {object_type}")
            while True:
                # Get user input for the selected option
                print("")
                program_search_selected = input("Enter the number of the option you want to choose: ")
                print("")
                # Validate user input
                try:
                    program_search_index = int(program_search_selected) - 1
                    if program_search_index == -1:
                        print("")
                        print(f"{current_time()} Selection canceled. Returning to the top.")
                        print("")
                        retry_step = 0
                        break
                    elif 0 <= program_search_index < len(program_search_base):
                        program_search_selected_entry_id = program_search_base[program_search_index].entry_id
                        program_search_selected_object_type = program_search_base[program_search_index].object_type
                        program_search_selected_program = f"{program_search_base[program_search_index].title} ({program_search_base[program_search_index].release_year})"
                        print("")
                        print(f"{current_time()} You selected: {program_search_selected_program}")
                        print(f"{current_time()} The selected program is a: {program_search_selected_object_type}")
                        print(f"{current_time()} The corresponding entry ID is: {program_search_selected_entry_id}")
                        print("")
                        retry_step = 1
                        break
                    else:
                        print("")
                        print(f"{current_time()} Invalid option. Please choose a valid number.")
                        print("")
                        retry_step = 3
                        continue
                except ValueError:
                    print("")
                    print(f"{current_time()} Invalid input. Please enter a valid number.")
                    print("")
                    retry_step = 3
                    continue
            if retry_step == 0:
                continue
            elif retry_step == 1:
                break
        # Select a Streaming Services Option
        while True:
            # Get the Streaming Services Offer based upon the selected Program
            services_search_base = details(program_search_selected_entry_id, country_code, language_code, True)
            services_search_results = extract_offer_info(services_search_base.offers)
            if not services_search_results:
                print(f"{current_time()} {program_search_base[program_search_index].title} is not currently available on any Straming Service.")
                print("")
                run_create = False
                break
            else:
                run_create = True
            # Display a list of Streaming Services Options to the user
            print("")
            print("Select a Streaming Service (or enter 0 to cancel and exit):")
            print("")
            for i, info in enumerate(services_search_results, start=1):
                print(f"{i}. {info['name']} ({info['price_string']})")
            while True:
                # Get user input for the selected Streaming Services Option
                print("")
                services_search_selected = input("Enter the number of the Streaming Service Option you want to choose: ")
                print("")
                try:
                    services_search_index = int(services_search_selected) - 1
                    if services_search_index == -1:
                        print("")
                        print(f"{current_time()} Cancelling...")
                        print("")
                        run_create = False
                        retry_step = 1
                        break
                    elif 0 <= services_search_index < len(services_search_results):
                        services_search_selected_service = services_search_results[services_search_index]
                        services_search_selected_url = services_search_selected_service['url']  # Save the URL
                        print("")
                        print(f"{current_time()} You selected: {services_search_selected_service['name']} ({services_search_selected_service['price_string']})")
                        print(f"{current_time()} The corresponding URL is: {services_search_selected_url}")
                        print("")
                        retry_step = 1
                        break
                    else:
                        print("")
                        print("")
                        retry_step = 3
                        continue
                except ValueError:
                    print("")
                    print("")
                    retry_step = 3
                    continue
            if retry_step == 0:
                continue
                break
        # Create directories (if ncessary) and file(s)
        if run_create:
            program_name = sanitize_name(program_search_selected_program)
            print("")
            print("Select a top level directory for the Stream Link(s):")
            print("")
            if program_search_selected_object_type == "SHOW":
                selected_prefix = get_button_selection("Select a Prefix option for the episodes:", prefix_options)
                create_directory(os.path.join(base_directory, program_name))
                create_season_folders(os.path.join(base_directory, program_name), starting_season, ending_season)
                    season_folder_path = os.path.join(base_directory, program_name, season_folder_name)
                    create_episode_files(season_folder_path, episode_count, selected_prefix, services_search_selected_url)
                print(f"{current_time()} Directory structure and files created successfully.")
            elif program_search_selected_object_type == "MOVIE":
                create_movie_file(base_directory, program_name, services_search_selected_url)
                print(f"{current_time()} File created successfully")
            else:
                print("")
                print(f"{current_time()} ERROR: Unknown Program Type")
                print("")
        # Check to re-run
        rerun_options = ["Yes", "No"]
        rerun_select = get_button_selection("Do you wish to run again? (Yes/No):", rerun_options)
        if rerun_select == "Yes":
            continue
        elif rerun_select == "No":
            break
        else:
            print("")
            print(f"{current_time()} Error encountered, exiting...")
            print("")
            break
    # Other Actions
    print("")
    print(f"{current_time()} End of current commands.")
    print("")
    exit()
    main()
The above script is a prototype proof-of-concept for the program search, selection of a program, and creation of expected Stream Link files. This is a fully functioning application with the following caveats:
  1. TV Shows are not getting individual episode URLs (yet). The API that is used to access the base data needs an update before that is possible. Also, given this current situation, I have opted not to get more granular with episode selection at this time.
  2. The Stream Links that are created might not be valid. I have especially noticed an issue with Disney+ that I'm working on a higher level approach to address. Although I know how to solve the issue for Disney+, I do not want to create fixes for individual services as it will be way too much to manage.
  3. In a similar vein, although almost all Hulu programs are available on Disney+, the underlying data provider is not up to date on this fact and will usually only offer Hulu instead of Disney+ and Hulu. Again, I already have a resolution for this, but would rather avoid dealing with a specific service this way.
That all said, here's how it looks:
At the beginning, you are prompted for certain conditions for searching. If you want the default options (United States, English, 9 Results), then you can just hit enter and parse past them.
At this point you can search for whatever you are looking for, not case sensitive. If you get enter-happy or forget to put anything, it will just return the most popular programs right now. Otherwise, you will see this:
From here, you can select 0 to search again, or select one of the numbers. If you mistype, it will warn you and let you select again until you make a valid choice. In this case, I'm going to select the first option:
The application confirms your choice and then offers you everywhere it is available and at what price (assuming you have a subscription for the $0.00 options). If it is not available anywhere, you will be told so and forced to the end of the routine (more on this later). Otherwise, similar to the prior step, you must select a valid option to move on, or 0 to cancel and maybe try again. I'm going to choose 9 for YouTube:
A confirmation appears for the selection and the URL. At this point, you would select a the directory where you want the file to be created (or, if a show, the parent directory). Note that because I am using Windows I am getting a pop-up selection box, but command line only systems would have to type in a directory path. This is the case for all popups below. Later, these will not exist and instead will default into their own directory in the Imports directory under Channels.
After selecting the folder, everything progresses as normal:
As can be seen above, a file is created automatically with the correct name and Stream Link inside!
Afterwards, you'll be asked if you want to run again and do another search.
JP_ScreenShot_2024_04_30_17_31_31
This will bring you back to the search menu. If you do any of the earlier opportunities to cancel, you will also end up here. Now that we are here, let's go through a TV Show. Back to the prior test, I'm going to select 6.
Now I get prompts for prefixes, number of seasons, and number of episodes per season. In the future, this will not be a selection at this point but part of the management system:
This all results in individual files being created:
Take note that the program had an invalid character (a colon :) that was removed. This would happen with a movie, as well.
And that's it! With this, we have proven that we can search a 3rd party source and create Stream Links based upon it. I'll also be looking into the reverse of this with selecting a Streaming Service and being presented with the newest additions to see if you want to create the Stream Links.
Enjoy!
This is looking good but is there a way to prevent the script from exiting after selection of one show/movie? I got multiple shows/movies that I want to add so going back and opening up the script all the time could be tedious
Done and done!
I've updated the script code and the example (a bit) in the post above.
