Im running my dvr server from my samsung tablet. Im trying to use streamlinks to add my Spider Man into the spider verse from amazon which is where i purchased it digitally. I put the files like in these images but i dont know why it does not appear in my library.
Two things:
- if you create folders in Imports/Movies, just use a name that does NOT end with '.strmlnk' but folders are not required for movies
- remove the '.txt' file extension at the end of the file name (the file extension must be '.strmlnk')
Imports
Movies
Spider-Man Into the Spider-Verse (2018).strmlnk
Now how do i get channels to recognize the streamlink?
They will be recognized when you create them correctly by fixing the mistakes noted by @mjitkop
Did you rename the folder and rename the file? Can you post a photo of how it looks now
I checked it and i forgot a the point before strmlnk. But it got added. I have a quick question. Will streamlinks effect my dbr storage by a lot?
No
Just a little follow up. Storage wise, no real concerns because they are less than 1kb each. But if you have a lot of them, you may notice the app start-up time is longer. I did some math about this in the past:
