streamLink=false Not working in virtual channel smart rule?
I’m not sure if this is user error or a bug, but I have a virtual channel with this advanced smart rule:
labels=[Star Wars] streamLink=false streamFile=false
I’m correctly getting the Star Wars movies in my virtual channel, but it is also grabbing a bunch of stream links I’m using, so things like Andor, the Mandalorian, etc., are all showing up.
Do I have the syntax wrong? Thanks.
i think it is
sourceType!=[Stream Files, Stream Links]
That did the trick. Thanks.
