Suggestions for features -
Way to remove tuner sources, or scan and validate them -
Button to facilitate moving and rebuilding the DVR database in a new location ( and maybe disable all recordings/watchers while happening)
Button to do complete check / rebuild of DVR database -
Add a flag or send a warning email to an admin when the router can't be discovered - I've had to go in and re-redo the port forwarding rules multiple times because they don't seem to stick, even though my router says the rules are in place - ???? - real pain when you discover the problem when away from home, and you can't do anything about it til you get back -
