Super Bowl LIX in 4k on TVE Fox?
From the article, it sounds like TVE auth won't be needed (like last year), so Channels TVE Fox won't work.
The Super Bowl will be distributed across Fox, Fox Deportes and NBCUniversal’s Telemundo, as well as NFL digital properties. Viewers will not have to pay a subscription fee or be a subscriber to a cable or satellite system to gain access.
Tubi will stream Super Bowl LIX in February for free on its platform using FOX’s feed of the game, the company announced.
Viewers will be able to watch the game on Feb. 9 when they sign up via email registration. There will be no Multichannel Video Programming Distributor authentication or credit card sign-up needed to be able to watch it.
A post was merged into an existing topic: Tubi for Channels docker
Please keep this thread on topic (Channels DVR TVE Fox channel).
Discussions about Tubi and the SB are in the Tubi for Channels docker topic
Unless we get an Experimental feature like this
Screenshot 2025-01-17 at 09-39-53
:interrobang:
Not going to happen
I get all Fox 4k games with the E+ docker container.
Does that use Fox TVE ?
Yes you have to use your provider credentials so that the docker can access the feeds.
Ah, thought so.
I can't get TVE Fox to stream in Channels DVR, so most likely wouldn't work in EPlus.
Yes you can't stream the Fox channel, it's only for sports events. And I'm not even sure the SB will be in 4k through the container because all the NFL games come from nfl.com which only sends out 720p (via NFL+.which is mobile only).
But if Tubi is going to do it in 4k I suppose that's an alternative.
I did some checking during the Fox game yesterday and Fox TVE did not work for me on 6002.
I also set a recording on the EPlusTV feed and it recorded in 4K HDR.
Yeah TVE for fox seems not to work ....
2025/01/19 10:23:14.236838 [ERR] Failed to start stream for ch6002: TVE: Stream Temporarily Unavailable
2025/01/19 10:23:14.237142 [HLS] Couldn't generate stream playlist for ch6002-dANY-ip192.168.50.186: TVE: Stream Temporarily Unavailable
2025/01/19 10:23:14.237295 [HLS] Stopping transcoder session ch6002-dANY-ip192.168.50.186 (out=0s finished=false first_seq=0 last_seq=-1)
Doesn't EPlusTV use the Fox TVE feed for the Fox channel?
Wondering how it can record when Channels Fox TVE doesn't work?
Yes, it seems to use TVE, but unlike Channels it provides a code to enter on the Fox Sports website. You authorize using provider credentials (YoutubeTV, for me) and the code. It's like it is mimicking an Android TV app.
:point_up_2:This is exactly what I saw yesterday :point_up_2:
