Keeps happening while trying to watch a good horror movie.
Logs have been submitted as 33031fdc-8114-4a78-83ec-a0dd0f3cc298 .
Just went back to the channel and it’s still happening.
That usually indicates a network issue. Either your home is dropping the connection; or more likely, their servers are having issues.
SyFy is 60 54 for me. and it not working gives error
[ERR] Could not start stream for TVE-Comcast_SSO ch6054 SYFY: TVE: Could not fetch playlist: tvecable-web-y.akamaized.net: get https://tvecable-web-y.akamaized.net/v1/master/8731b4a01f4c78c237c9c596da70a09cf1742ab7/PROD_ONEAPP_WEB_DAI/master.m3u8?aws.sessionId=09a0d95f-571d-46fe-9940-44892105b65c&hdnts=exp=1665363104~acl=/v1/master/!/Content/~hmac=5c108d75c0e75d7a944413e609bd7249ef9924a39417a45dc381a8dcf6324e2d: 504 Gateway Time-out
guessing some issue on their end
Now is happening on E! 6056. Other channels all day have been fine.
My network was s perfectly fine. I’ve had Channels for over 2 years and nothings changed in my setup.
I was not specifically saying something was wrong within your home network. Your network includes your connection to the internet through your ISP; perhaps they are having issues with their gateways/routers.
I also indicated the issue could be with the network's website.
504 Gateway Time-out seems to indicate it's a "them" problem, not a "you" problem.
Of course, your logs may show something different; but without sharing them all anyone can do is guess as how to help you.
Definitely working
2022/10/09 21:04:25.463144 [TNR] Opened connection to TVE-Cablevision for ch6054 SYFY
2022/10/09 21:04:33.831958 [SNR] Buffer statistics for 192.168.1.143 (iPhone) for ch6054 SYFY: buf=0% drop=0%
2022/10/09 21:04:33.841960 [TNR] Closed connection to TVE-Cablevision for ch6054 SYFY
2022/10/09 21:04:37.889638 [TVE] stream timestamps: syfyp: start_at=2022-10-09T21:03:12-04:00 end_at=2022-10-09T21:04:00-04:00 live_delay=31.296629s
2022/10/09 21:04:37.889813 [TNR] Opened connection to TVE-Cablevision for ch6055 SYFYP
2022/10/09 21:04:47.344227 [SNR] Buffer statistics for 192.168.1.143 (iPhone) for ch6055 SYFYP: buf=0% drop=0%
2022/10/09 21:04:47.353342 [TNR] Closed connection to TVE-Cablevision for ch6055 SYFYP
2022/10/09 21:04:49.102656 [TVE] stream timestamps: e: start_at=2022-10-09T21:03:25-04:00 end_at=2022-10-09T21:04:13-04:00 live_delay=29.528645s
2022/10/09 21:04:49.102887 [TNR] Opened connection to TVE-Cablevision for ch6056 E
2022/10/09 21:04:58.501791 [TVE] stream timestamps: ep: start_at=2022-10-09T21:03:31-04:00 end_at=2022-10-09T21:04:19-04:00 live_delay=33.026779s
2022/10/09 21:04:58.501955 [TNR] Opened connection to TVE-Cablevision for ch6057 EP
2022/10/09 21:05:00.634321 [SNR] Buffer statistics for 192.168.1.143 (iPhone) for ch6056 E: buf=0% drop=0%
2022/10/09 21:05:00.647633 [TNR] Closed connection to TVE-Cablevision for ch6056 E
2022/10/09 21:05:07.367676 [SNR] Buffer statistics for 192.168.1.143 (iPhone) for ch6057 EP: buf=0% drop=0%
2022/10/09 21:05:07.373090 [TNR] Closed connection to TVE-Cablevision for ch6057 EP
So mine says…
Error during live stream for ch6055 SYFYP: astits: fetching next packet failed: astits: fetching next packet from buffer failed: astits: reading 188 bytes failed: hls: temporary failure while downloading
I’m gonna reboot my spectrum modem and nighthawk router. I can’t wait for fiber to be installed next summer.
Still happening for the same error message and reason
Something has to be going on outside my control.
Try faster dns? Can’t hurt.
Channels could not download the next part of the stream, so it closed the connection.
Often this could be the result of CDNs re-routing the requests. A good way to check this is to ensure you are using your ISP-provided DNS servers, and that you are not using any VPNs or other filtering software (such as Pi-Hole) on your home network. Setting things to their defaults can often remedy this issue.
Thanks. I am using everything as I’ve always used it. I’ve never changed the dns settings.
All I can offer is to try it on their website and see if it works without issues. If there are errors there, then that would likely confirm the issue is theirs.
Ok so little test I did here. I put the same channel, Syfy, on my Apple TV connected to my home Spectrum internet and on my iPhone 14 ProMax on AT&T FirstNet LTE both showed connection lost at the sage time so the issue is with the networks stream or channels
Tested both my iPhone and AppleTV on my home network. AppleTV using Channels, and iPhone using the Syfy app. The iPhone continued to play when Channels went Connection Lost. So this tells me that the issue is definitely with Channels and not my internet or network.
Channels uses the website for its source; the app uses NBCU's own internal infrastructure. They are not the same.
Yeah I think its most probably a dns issue. I had similar probs where for 'no apparent reason' streams would dropout. Changing the DNS fixed it, especially relevant if you have a non standard setup
I did go into my routers settings and changed the DNS to Googles (8.8.8.8 and 8.8.4.4) but have the same issue.
Any thoughts how to fix this? Maybe a developer can chime in with some input? Lots of things I’d like to watch for Halloween and can’t.
