Hello All!
I have ChannelsPlus running really well on my synology DS1819+ and I would like to know if there is a way to tell the DVR not to exceed 2TB of disk usage? Right now, it thinks it has the entire NAS Volume to use...
Matt
Hello All!
Matt
Only way I know to limit is through disk quotas, but Channels DVR runs as root, so I don't think it's possible.
A workaround would be to create a volume for Channels DVR to record to and other volumes for the rest of your stuff.
Thanks - I will probably drop a couple of more drives in there and call it done...
I tried setting quota and ran in to problems - channels will recognize the entire volume. The OS will just throw errors once the quota is used and just cause problems.
