Synology DiskStation DS2415+
Featuring a quad-core processor, hardware encryption engine, and flawless software integration, DS2415+ is a powerful, expandable 12-bay NAS server that delivers outstanding speed and accelerated data encryption. Easily scalable, the DS2415+ can be equipped with up to 6GB of DDR3 RAM and host up to 240TB of raw capacity with a Synology DX1215 expansion unit.
I see this unit comes with an Intel Atom C2538 64-bit processor.
Will this unit handle recording 9 shows simultaneously?
Can I also use Channels DVR Comskip with this unit?
https://www.synology.com/en-us/products/DS2415+#overview
The Intel Atom series does not offer hardware transcoding. Everything else is great, and should work well for multiple recording/playback and comskip.
Software transcoding will work pretty well on there too since it’s a quad-core.
