I'm trying perform manual install in Synology Package Center of ChannelsDVR_1.0.4.spk package on Synology DS409+ running DSM 4.2-3259 (not using putty) following instructions on https://getchannels.com/dvr-server/#synology
I first downloaded the ChannelsDVR_1.0.4.spk file. Then did manual install and selected the downloaded spk file.
I get error from Channel DVR
Failed to install the package
- curl: (60) SSL certificate problem: unable to get local issuer certificate
More details here: http://curl.haxx.se/docs/sslcerts.html
curl performs SSL certificate verification by default, using a "bundle"
of Certificate Authority (CA) public keys (CA certs). If the default
bundle file isn't adequate, you can specify an alternate file
using the --cacert option.
If this HTTPS server uses a certificate signed by a CA represented in
the bundle, the certificate verification probably failed due to a
problem with the certificate (it might be expired, or the name might
not match the domain name in the URL).
If you'd like to turn off curl's verification of the certificate, use
the -k (or --insecure) option.
Stuck.
