Synology NAS - Docker Help
I just successfully transfered drives to new NAS. But Channels will not open now, likely because the new NAS has a different IP than the old one. What is best way to address that? Note - since drives were migrated to new NAS, it has the same DNS name, but different IP. And NAS has a setting option to internally/manually change IPv4
Go to router and allocate IP of old NAS to new one? If so, just assign it, and restart the NAS? Or is there a way to change Channels to new NAS IP? Or do I have to reload Channels maybe? Or maybe there is another way I am not aware of...? Thanks!
Most likely this
You can make a dhcp reserved IP address for your new nas on your router. A change in IP address shouldn't affect running Channels DVR.
I reserved old IP, but still had to reinstall Channels and restore a backup. Was easy. All works fine. Now to figure out this "docker thing." lol. Do you have a link to a "how to" page to create and setup the new channel sources via Container Mgr in Synology? Like where/how to run the command to create new playlists? I don't understand how a command is an image? Thanks.
If you don't understand docker and don't want to spend the time to learn it, I recommend using this.
You just have to install one docker container, Portainer, and it will do the rest.
The instructions are in his first post.
Follow-up in that topic if any questions.
I have installed Portainer. Not doing Olive Tin yet (since I am already overwhelmed). Do you have a link on how to use Portainer, for example, to install the Samsung TV image created recently? I need step-by-step (like where to run the command, and if I need to create container/image or both before. I am not a programmer.) Also, I do see the Samsung image in Synology Container lookup. Same thing? Settings for adding?
Create a stack for it in Portainer using bnhf's compose statement and environment variables
Learn how to use your tool of choice (Portainer or Docker Compose or Docker command line)
Sorry to revive this old thread, and if this isn't the proper place for this question, please let me know.
Basically, I've had ChannelsDVR running on my Synology DS218+ for years, and for the last year I've had TVE through YTTV working perfectly. Something happened within the last week and now I can't get YTTV to let me login anymore through the ChannelsDVR Add Source GUI.
I've read several threads in here about how it works better if CDVR is running through Docker, so I've tried to familiarize myself with that. I've got Docker running and installed containers of ChannelsDVR and Portainer. On the ChannelsDVR install, I mounted two volumes as listed in the official install notes. I can't see where the info is for mounting any volumes for Portainer.
From reading several threads, it sounds like I'm going to want to install OliveTin and get Project One Click working, but for now I just want to get CDVR running through the Docker install and then see if I can add YTTV as a source.
Here's where I am and I have no idea what to do next:
Any help you can provide would be greatly appreciated!
